AC Condensor Question
PostPosted: Fri Jan 07, 2011 4:01 am    Post subject: AC Condensor Question Reply with quote
I have a PITA favor for anyone who has an AC condensor laying around. I need a measurement for the offset between upper and lower mounts (the top mounts attach forward of the rad subframe, and the bottom mounts rearward, against the lower rad mounts).
I know this will be difficult to measure, but it just needs to be approximate.
Thanks!
Rasta
PostPosted: Fri Jan 07, 2011 5:17 am    Post subject: Reply with quote
If I understand this correctly, you want the measurement from the centerline of the upper and lower mounting grommets? That's 14 inches. I have a condensor out on our back deck if this is incorrect.
PostPosted: Fri Jan 07, 2011 6:34 am    Post subject: Reply with quote
I have that measurement. . .looking for the distance between the plane of the rear side of the upper mounts, and the plane of the front side of the lower mounts.
My thinking is that these are two parallel planes, slightly offset since they bolt up to opposite sides of the rad subframe.
Confusing enough?
PostPosted: Fri Jan 07, 2011 8:49 am    Post subject: Reply with quote
Hmm, might be easier if you spend 20 bucks on shipping, and I'll send you the damn thing~! I have no clue, the 'ear' mounts on all four corners look the same to me. Plane or no plane!!
PostPosted: Fri Jan 07, 2011 9:26 am    Post subject: Reply with quote
So if you lay it down, the mounting ears are the same distance from the ground?
There I go, overthinking schitt again.
