az_probe
Posted: Sat Jul 31, 2010 12:41 pm Post subject: Newb HELP Please |
| ok so about 4 months ago my 87 924s died on me... so i thought it was the dme relay and it was but after i replaced it, it wouldnt start so i started toubleshooting and found my fuel pump had died so i replaced that and it works, then it wouldnt get spark traced that to a bad coil replaced that still wouldnt start, so i checked my speed and ref sensors and they fell apart so put new ones in still no start then i had my ecu tested and it was bad so i put a reman. one in and it still wont start i am gettin tach bounce i have fuel and spark and all my vaccuum lines are good please help i am about to give up on my baby |
ic932
Posted: Sun Aug 01, 2010 12:10 am Post subject: |
| I guess you need to run a compression check to eliminate the worst case scenerio - no compression due to bent valves. |
John_AZ
Joined: 25 Jun 2008 Posts: 130 Location: Arizona ~Carefree Highway~
Posted: Sun Aug 01, 2010 1:35 am Post subject: |
New fuel pump, check
New sensors, check
New dme/fuel pump relay, check
New ECU, check
Coil, check
Fuel, Spark, tach bounce, check
Vacuum lines, check
Simple stuff to check,
Make a 3 wire DME/fuel pump relay jumper per Clarks
http://www.clarks-garage.com/shop-manual/fuel-05.htm
The negative ground on the bell housing-clean. Put a piece of tape over the TDC hole so a bold does not fall in the clutch.
Clean all harness connectors on top of the engine---carefully.
Make sure the AFM harness connector is tight. Check the AFM for "barn door" operation.
Gap the sensors and clean where the sensors connect on top of the rear engine.
Make sure your Rotor is tight and the cap is clean.
Belts, recheck the timing marks on the cam belt.
Read a couple of "NO Start" procedures:
http://benms.com/944nostart.html
http://www.clarks-garage.com/shop-manual/ts-01.htm
GL
John |
az_probe
Posted: Sun Aug 01, 2010 4:32 am Post subject: |
| thanks john i was hoping you would respond after lookin at your other post i have already made a jumper but i will check afm and go over all my grounds today hopefully this will fix her lol |
ic932
Posted: Sun Aug 01, 2010 4:59 am Post subject: |
Don't forget to check the compression too.....its probably the first thing you should do lol.
Think diagnostics ONCE you know there is something worth diagnosing. |
Posted: Sun Aug 01, 2010 12:51 pm Post subject: |
| Have you checked to see if the injectors are really firing? If your FPR (fuel pressure regulator) is bad it can fail closed causing the fuel pressure to rise and the injector drivers in the ECU to shut down. It can also fail open (less common) where fuel circulates through the rail but does not build enough pressure. You only really have fuel if it is properly spraying from the injectors. |
az_probe
Posted: Mon Aug 02, 2010 9:52 am Post subject: |
| ok so took the cap off and made sure rotor was tight cap was clean but recleaned it anywayall sensors and grounds are clean afm harness is tight no breaks in wiring i did the listen for the click test on my injectors and all is good there they each click away like little champs it still only cranks and wont start this is starting to get annoying lol |
az_probe
Posted: Mon Aug 02, 2010 10:05 am Post subject: |
| also after trying to start it today i waited bout ten min and cracked open the fuel rail and not a drop came out...took it all the way off and nothing left it off and cranked and it sprayed like no tomorrow is this from the fpr or is this another issue???? |
