Posted: Thu May 27, 2010 1:13 am Post subject: Koni Fitment |
Boy, those adjusters sure look close to the hood. Anyone had any issues with this? _________________ Toofah King Bad
Posted: Thu May 27, 2010 1:25 am Post subject: |
It's definitely a known concern on the 931, particularly on the NACA duct side. CLOSE HOOD CAREFULLY.
http://www.924board.org/viewtopic.php?p=117438
http://www.924board.org/viewtopic.php?p=289095
I don't have Koni's on the 941, but at some point in it's past, the NACA inside surface of the NACA duct met the top of the strut mount. It's not an issue at present, so I don't know when it occurred (sometime prior to me owning the car...). But the NACA duct is VERY tight to the strut mount regardless of what shocks you use (as you probably well know). _________________ erstwhile owner of just about every 924 variant ever made |
9xx
Joined: 18 Jun 2006 Posts: 627 Location: Jarvenpaa, Finland
Posted: Thu May 27, 2010 1:29 am Post subject: Re: Koni Fitment |
| Rasta Monsta wrote: | | Anyone had any issues with this? |
Yes. My car has a small ding on NACA duct because the adjuster hit it. _________________ Mikko
All gone: 931 '82 Alpine White, original option "220" G31 with LSD + 3 x 944 |
Posted: Thu May 27, 2010 1:43 am Post subject: |
Hmm, I guess a small spacer is in order. Anyone have one off the car for a measurement or two? _________________ Toofah King Bad
john h
Posted: Fri May 28, 2010 3:20 pm Post subject: |
When I fitted Koni's in 1987 they punched a hole in the NACA scoop. The solution to this wascut the end of an acorn lug nut and welded this in place. Looked ok once it was painted but in teh mid 90's when I had the hood off during a racing season we made a very small dimple which looked nicer than the top of the acorn nut (almost like a factory item) _________________ Remember a Porsche is not just for Christmas,
stevekat
Posted: Fri May 28, 2010 4:04 pm Post subject: |
My car has a hole drilled, and a plastic cap in place. I like the dimple idea. _________________ "Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Posted: Mon May 31, 2010 3:20 pm Post subject: |
SOLUTION:
Before:
Spacer (3/8"):
Spacer and Spring Hat:
Spacer installed:
After:
I hope that is low enough not to dent my hood, but that's as low as it can go.
Final report coming! _________________ Toofah King Bad
Posted: Tue Jul 20, 2010 7:16 am Post subject: |
Hood closes fine. _________________ Toofah King Bad
