Brake disc thickness minimum
jbwheele
PostPosted: Tue Jul 13, 2010 11:35 am    Post subject: Brake disc thickness minimum Reply with quote
Hy guys /gals
Is the minimum thickness on the rear disc M471 931 82 model 18.5mm?
what is fronts?
Joe
Joe
82 932 Stripped bare full rebuild
80 932 GT Lookalike Engine S2 swap
Ozzie
PostPosted: Tue Jul 13, 2010 7:21 pm    Post subject: Reply with quote
According to my book the minimum for
fronts is 19.1 mm
rears is 18.6
Its AUTO and its BLACK
Montego Black on black/red
emoore924
PostPosted: Wed Jul 14, 2010 8:16 am    Post subject: Reply with quote
Usually they stamp it on the edge of the rotor someplace too...
Look for some numbers along the edge by the vents. Only reason I'm bringing it up is if it has aftermarket rotors that have some other spec than factory...
