malpaslane
Posted: Sat Jul 10, 2010 1:29 am Post subject: CARRERA GT BELT TENSIONER BOLT |
Hi All, i,m working on a carrera gt for a friend, the car has been sat in a garage for the pass 15 years and he,s picked it up for a bargin price of £8k (they,re fetching £20k over here at the moment) i,m getting the car ready for the road again and there,s a problem with the belt tensioner bolt, the o.e tensioner is wider than the new one that porsche have supplied and the bolt is now to long , does anyone know the part number i need as the porsche dealer over here doesn,t know, i would say i need a bolt of 55mm, the bolt that came out is about 70mm.
any help would great,
many thanks
Rik _________________ 931 1982, PAIN IN THE ARSE,BUT GETTING THERE. 911 1976 2.7. 931 1981 S2(NON RUNNER) ALFA 156 SPORTSWAGON. |
Posted: Sat Jul 10, 2010 10:35 am Post subject: |
Hi Rik, not sure what you've got with that GT, but the tensioning roller bolt, and for that matter, the tensioner, are identical for 924/931/GT. As the belt is identical, so too are tensioners and associated hardware.
FWIW the bolt is indeed M10 x 55 Part # N 010 455 3 or go to your local bolt supplier and get a suitably graded one.
Seems like something odd about the setup on the GT. As you have 931s check the differences/or similarities. Was the GT set up for some sort of wider drive belt or have you a GTS? _________________ 80/81 932/8 ROW |
Posted: Sat Jul 10, 2010 10:55 am Post subject: |
There were two versions of the tensioner: 056 109 243 D thru 1979; 026 109 243 F from 1980 onward. I always thought they were different between NA and 931 because my 1981 NA had the longer bolt when I got it and my 931s had the shorter bolt; but according to PET, such is not the case. The version using the shorter bolt was introduced in 1980 as an improved design or something, and is correct for both NA and 931 applications. The tensioners themselves are interchangeable with respect to the belt, as long as you have the correct length bolt. I believe the earlier style can be tensioned with an open end wrench, while the later uses the funky two-pin belt tensioning tool. Since the parts are interchangeable, somebody somewhere along the line must have gotten ahold of the earlier style when ordering and installed it on your car. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sat Jul 10, 2010 11:13 am Post subject: |
I was notified of a neat tensioner on e- bay a couple days ago.. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
malpaslane
Posted: Thu Jul 15, 2010 12:55 am Post subject: |
Thanks guys for the help, it does look like the car has had an old style tensioner put on, there are afew things on the car that have been played with, some better than others, but the cars in pretty good shape, just needs bring back to life after a 15 year rest...
cheers
Posted: Thu Jul 15, 2010 1:03 am Post subject: |
OK, where are the pix?
I'm so jealous...wish we had more CGTs over here... _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Thu Jul 15, 2010 8:43 pm Post subject: |
You're quite right Dan, about there being another type of tensioner available. I've never seen the other type, but I'm not altogether sure it's just an early version.
What I mean is.....in talking to a mate in the south of our country who is also a Toofah fanatic, I mentioned, amongst other things, the early tensioner. He advised he replaced a tensioner around 2 years ago and the new tensioner (from the Melbourne OPC) had a large nut affair seemingly welded onto the front of what we know as the 'normal' tensioner, necessitating the use of a longer bolt. The belt spacing was still the same width, but the tensioner was considerably thicker due to the extra nut arrangement. He also advised that he had to relieve the water pump housing by several mm to accomadate this weird tensioner.
Curiouser and couriouser! _________________ 80/81 932/8 ROW |
Posted: Thu Jul 15, 2010 11:30 pm Post subject: |
Watch it (dont over tension belt thinking the belt whine sounds
like a supercharger). Doing so adds a lot of stress, Ive had one come aprt on me before 'now' cant say thats my cause for tension failure.
This new looking one i talked bout earlier from e-bay curled my toes
looked beefier & wider 4 some reason. Probly not though. _________________ 1979 porsche 924 Na
Zuffen
Joined: 31 Jul 2001 Posts: 1427 Location: Owasso, Oklahoma 74055
Posted: Sun Jul 18, 2010 1:10 pm Post subject: |
if you have never done the belt on a 924T, I would seek out experienced owners/mechanics to aid in the changing of the belt
the CGT is an interference engine and costly to repair if you bend a valve.
the pistons are NLA through Porsche. _________________ Bob Dodd - 924turbo@cox.net
I have Way too many cars, parts for the 931,944 and 951 |
