blurred_line
Joined: 23 Jun 2010 Posts: 40 Location: Vortex of Hell (Illinois)
Posted: Tue Jun 29, 2010 12:24 am Post subject: 931 upgrades |
Hey everybody. I just bought a 1981 924 Turbo and I'm rebuilding it. The motor already had a broken Timing Belt so the head is out being working on right now. The questions that I have is I'm looking for a performance exhaust system, a high-flow radiator and an intercooler for my 931. Does anybody have any sugestions? Do the 944 Turbo exhaust system fit the 931's? How about the radiator? Any help would be appreciated. _________________ 1981 924 Turbo |
Posted: Tue Jun 29, 2010 12:31 am Post subject: |
I like my Ron Davis rad. The 931 exhaust flows pretty well. . .but if you want it louder I believe a 944 aftermarket muffler will work.
As for intercoolers, please use the SEARCH function. There have been many different successful installs by members here. _________________ Toofah King Bad
Posted: Tue Jun 29, 2010 12:52 am Post subject: |
The cat-back is the same for the 931 and the 2.5L NA motors (924S & 944). The 931 exhaust is already 3" so not sure what you expect to gain, other than a cat-delete or a freer flowing muffler. As for cat-delete, the cat section is unique to the 931, and I don't believe there are any aftermarket alternatives, so you'd have to have something custom made.
Regarding intercoolers and other performance mods, here is a good thread to start with: http://www.924board.org/viewtopic.php?t=25795
An alternative to the radiator is to go with a 924S/944 rad, or better yet, a 951 rad. While not directly swap in, they should fit the profile and should be fairly easy to adapt with a little creative bracket fabrication. The other thing to consider is replacing the somewhat anemic OEM fan with a lower profile, higher efficiency fan setup such as a Spal or Davies-Craig unit, along with a properly designed shroud. The OEM shroud is probably not the best design possible. _________________ erstwhile owner of just about every 924 variant ever made |
9xx
Joined: 18 Jun 2006 Posts: 627 Location: Jarvenpaa, Finland
Posted: Tue Jun 29, 2010 3:06 am Post subject: |
| ideola wrote: | | The cat-back is the same for the 931 and the 2.5L NA motors (924S & 944) |
Are you sure? 944 rear silencer has a 3-bolt flange whereas 931/951 rear silencer has a 4-bolt flange. 931 rear box = 951 rear box. (I think ) _________________ Mikko
All gone: 931 '82 Alpine White, original option "220" G31 with LSD + 3 x 944 |
Posted: Tue Jun 29, 2010 5:14 am Post subject: |
Yeah, I'll be the first to tell that the 931 and 924S/944 use different flanges from behind the catalytic converter.
If you want a cat-back exhaust look at 944 Turbo options.
Additionally the stock exhaust is 2.5". _________________ [This Space For Rent] |
Posted: Tue Jun 29, 2010 8:02 am Post subject: |
Sorry about that! 951 cat-back it is, not 924S/944. _________________ erstwhile owner of just about every 924 variant ever made |
gegge
Posted: Tue Jun 29, 2010 4:12 pm Post subject: |
The 931 exhaust is 60mm OD which makes a 2,5" an easy upgrade since it is slip-on. _________________ Carl Fredrik Torkildsen
blurred_line
Posted: Wed Jun 30, 2010 12:21 am Post subject: |
So let me get this correct, the 944 Turbo (951) cat-back system will bolt on to my 924 Turbo (931)? I found a cat-back system that will give me around 26 hp.
Also where can I get a 1.0 bar waste-gate spring?
There's so much info here it's hard to find everything. I could spend days on here but my work wouldn't like that very much.  _________________ 1981 924 Turbo |
Posted: Wed Jun 30, 2010 12:30 am Post subject: |
| blurred_line wrote: | | I found a cat-back system that will give me around 26 hp. |
who said that? _________________ Supercharger and EFI kits
https://www.the924.com |
Posted: Wed Jun 30, 2010 1:13 am Post subject: |
| blurred_line wrote: | | Also where can I get a 1.0 bar waste-gate spring? |
I have one (Weltmeister 1.0 BAR) you can have for $50, shipped. _________________ Toofah King Bad
yea why did u pick that # thats insane. & not possible. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
blurred_line
Posted: Wed Jun 30, 2010 3:40 am Post subject: |
Ok it's not a cat-back it's a full system, sorry about the mis-type. But the system is from Fabspeed, it's for a 944 Turbo but here's the link http://www.fabspeed.com/944Turbo.html I'm going by what they are saying. _________________ 1981 924 Turbo |
gegge
Posted: Wed Jun 30, 2010 4:05 am Post subject: |
Bypassing a 25 year old catalytic converter could be the reason for the hp gain. . A tuned 951 will gain from a full 3" but a 2,5" system should be adequate for 931 powerlevels _________________ Carl Fredrik Torkildsen
Posted: Wed Jun 30, 2010 4:15 am Post subject: |
Yeah, that 26 HP sounds like about 10% of stock 951 output. So, if the 10% is correct (debatable) you are looking at 15 HP on a stock US 931. _________________ Toofah King Bad
Khal
Joined: 26 Sep 2003 Posts: 4872 Location: Sunny and lovely interior BC, Canada
Posted: Wed Jun 30, 2010 8:29 am Post subject: |
| ideola wrote: | | As for cat-delete, the cat section is unique to the 931, and I don't believe there are any aftermarket alternatives, so you'd have to have something custom made. |
Euro models (at least, some of them) don't have catalytic converters. Finding/importing a Euro exhaust system might be more trouble than it's worth, though. _________________ '80 924 Turbo |
