oil pressure
dash16
PostPosted: Sat Jun 26, 2010 3:33 am    Post subject: oil pressure Reply with quote
it should always be at least above 2 on the gauge, correct?
and 5 on the the throttle?
what if after warming up, you're at like 1.5? and at like 4 on the throttle?
is this a sign on an issue? what could it be if you're not low on oil?
thanks
1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS
Rich H
PostPosted: Sat Jun 26, 2010 4:12 am    Post subject: Reply with quote
You should always have some on the gauge at al times, and more when you are on the move. While it's >1 hot idle then don't worry about it.
Rich
TJC
PostPosted: Sun Jun 27, 2010 1:05 am    Post subject: Reply with quote
I don't think you have a problem. The Porsche spec ( per Porsche publication WKD 423 320, 924S/944 Model Dimensions and Tolerances) is "approximately 4 bar at 5000 RPM @ 80 degrees C oil temperature".
For what it's worth, our '87 has about 1.5 bar at hot idle and 4 to 4.5 bar at speed. We use Mobil 1 and the ambient air temp here is in the 90's now.
An "old" rule of thumb is that hot oil pressure should be at least 10 psi for every 1000 RPM.
'95 BMW 318i/5 ..."Pearl"
'04 BMW X3..."Xander"
Still on the Prowl!
www.ttrs1.com
PostPosted: Sun Jun 27, 2010 3:37 am    Post subject: Reply with quote
Electric guages can vary. Before I got excited I would screw a mechanical guage into the engine and check the pressure there.
