Duncan
Joined: 04 Nov 2002 Posts: 425 Location: Delft, The Netherlands
Posted: Sun Aug 29, 2010 6:19 pm Post subject: cleaning medium blasted manifold |
I bought a medium (dont know what medium) blasted inlet manifold. I also had the flange flattened.
But just before fitting it I realised the inside is not clean at all at the moment and any residu of the blasting/machining will be going right in the block.
How should it be cleaned to avoid any damage?
Cheers,
Duncan _________________ 1983 NA Alpineweiss since 2001
Peugeot 205 Generation |
Posted: Sun Aug 29, 2010 8:38 pm Post subject: |
Lots of compressed air. _________________ erstwhile owner of just about every 924 variant ever made |
Duncan
Posted: Sun Aug 29, 2010 9:09 pm Post subject: |
Thats what the machinist said and did.
But I am still reluctant to bolt it to my overhauled engine...
Some bathing? _________________ 1983 NA Alpineweiss since 2001
Posted: Sun Aug 29, 2010 11:44 pm Post subject: |
Sure, soak it in some water with detergent. That should help loosen any grit that might be stuck in oil residue. -And run a bottle cleaning brush through it.. Hose 'er down, and let 'er dry. _________________ "..it's made in Germany. You know the Germans always make good stuff."
