Put rear sway bar on before or after alignment?
TBrown
PostPosted: Tue Jun 08, 2010 2:38 pm    Post subject: Put rear sway bar on before or after alignment? Reply with quote
Should I install the rear sway bar before or after I get my alignment? I read that the drop links mount on the eccentric bolts in the rear end? And that when you install the rear sway you can mess up the alignment.
Also if anyone has a rear sway bar drop link they would be willilng to sell that would be awesome. The po only gave me one.
Tangerine Dream- 1980 924 Turbo
Silver Surprise- 1979 924 Turbo
1977 International Scout ii
1982 Yamaha Sr185
1978 Kawasaki KZ650
1974 Honda CB360
1973 Honda CB750
Rich H
PostPosted: Tue Jun 08, 2010 4:53 pm    Post subject: Reply with quote
Fit the sway bar eccentrics before defiantely so you can bolt the bar on at your leisure whenever, it'll make no difference to the align.
