Power Brake Booster?
the_mad_electrician
PostPosted: Thu Feb 04, 2010 11:29 am    Post subject: Power Brake Booster? Reply with quote
After actually getting the bleeders on the front open and getting all the air out of the lines the brakes are still spongy and the car is hard to stop. Could it be the power brake booster? or the master cylinder? how do I test the booster?
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
PostPosted: Thu Feb 04, 2010 12:33 pm    Post subject: Reply with quote
How old are your brake hoses (10 year expiration date)?
The rear drum brakes need to be adjusted on a regular basis, when were your's done last?
StienbargerR
PostPosted: Thu Feb 04, 2010 6:13 pm    Post subject: Reply with quote
+1 on rear drum brakes. They aren't like new brakes which auto adjust. I had a similar problem and I think the drums weren't adjusted correctly.
Ryan
1978 924 NA
-250lb lowering springs, Euro Pistons
PostPosted: Thu Feb 04, 2010 10:48 pm    Post subject: Reply with quote
+1 on the rear adjustment. Here's a related thread
http://www.924board.org/viewtopic.php?t=31382
the_mad_electrician
PostPosted: Fri Feb 05, 2010 9:43 am    Post subject: Reply with quote
I think it might be the lines as far as I know they are the originals from 1976. The car is not stoping at all until I get to the last 1/8 of the distance of travel.
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
chad-tanner
PostPosted: Fri Feb 05, 2010 10:26 am    Post subject: Reply with quote
You have air in the master cylinder,The master cyinder will need a good bleeding before you bleed the lines again.
77.5 Porsche 924/4.9L cadillac swap
Inspector: These brakes look completely inadequate.
Burt Munro: Well, I'm planning on going, not stopping.
