Battery box drain?
endwrench
Guest
PostPosted: Mon Jun 03, 2002 10:09 am    Post subject: Reply with quote
At some point in the past of my car the battery box rotted out and was repaired with fiberglass. They seemed to have done a fine job but there is no provision for water drainage. Holds water like a bathtub everytime it rains! Where should I drill a water drain? Where is the stock one? Sounds like a silly question but I just don't want to drain on the passengers feet!
Todd
924_fan
Guest
PostPosted: Mon Jun 03, 2002 11:13 am    Post subject: Reply with quote
The drain is the hole in the firewall next to where the battery cable comes through to go to the starter. Typically this gets clogged with debris and needs to be cleaned out. If you still have the rubber cap over the drain, make sure that the rubber flap moves freely.
endwrench
Guest
PostPosted: Tue Jun 04, 2002 5:53 am    Post subject: Reply with quote
Ahh, thanks! I guess I didn't look to hard! Looks like they filled it half way with fiberglass resin so I will have to grind it out to make it drain.
Todd
Guest
PostPosted: Tue Jun 04, 2002 5:57 am    Post subject: Reply with quote
any suggestions as too how to make it drain better on both sides
