dreamgts
Posted: Tue Jan 05, 2010 2:44 am Post subject: Points to Electronic ignition swap |
I have a 1979 924 which funnily enough has points in the distributor Im sure its a 1979 model cause the chassis no states so. I would like to swap/eliminate the points and install an electronic ignition system or an original Transisorised ignition which is stated by Hayes as supposed to be installed. I would appreciate any info on this too. BTW guys thanks for all the info your sending or posting on my other threads, As soon as I start the project I will be posting some pics (if i find a way to) Im also using search as my friend as recommended.
Thanks
dreamgts _________________ 2 PORSCHE 924 (CURRENT PROJECTS)
2 CLASSIC CORTINAS (FINISHED)
1 CLASSIC FIAT(FINISHED)
1 CLASSIC FIAT 132 2000CC(JUST PURCHASED)
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
Posted: Tue Jan 05, 2010 3:29 am Post subject: |
I have a rebuilt NA ignition distributor and an ignitor box (not on my site yet) that are both available. However, these are US parts and may not be ideal for your application, unless you had the distributor recurved to Euro specs. _________________ erstwhile owner of just about every 924 variant ever made |
dreamgts
Posted: Tue Jan 05, 2010 4:33 am Post subject: Points to Electronic ignition swap |
ideola wrote: | I have a rebuilt NA ignition distributor and an ignitor box (not on my site yet) that are both available. However, these are US parts and may not be ideal for your application, unless you had the distributor recurved to Euro specs. |
Hello ideola
My 924 is definetly EURO spec originally and hasnt been converted the chassis number being 9249106351, I believe the digit 1 indicates EURO. The engine is an XK. If your system is applicable I would surely considering buying it. But your the expert here so you have to tell me what the differences are. By the way im looking at a thread were electonic injection system (ARvidw) was fitted on a factory intake the thread wasopened by buldogo 2, there are some of your comments there which Im about to look at as soon as I post this. Is it possible to fit the same system to my 924 (Max) any major complicated changes to do?
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
Posted: Tue Jan 05, 2010 4:55 am Post subject: |
EFI (electronic fuel injection) is not a trivial conversion. I am working on developing some bolt-on components, including a fuel rail, and crank trigger wheel for electronic ignition, and I've found a source for flow-matched injectors. However, there's more to it than that...you still need to find an ECU, either an open source Megasquirt approach, or an aftermarket product like 034Motorsports, DTA Fast, VEMS, or a number of others. A thorough read of the Engine Management section of the Performance Upgrades thread would be a good idea, as it will help you understand what's involved with an EFI conversion, point you to several examples here, so you can judge for yourself if EFI is a path you want to go down.
One other option is sort of a hybrid approach, and that is to retain the stock CIS system, but to replace the warmup regulator with the so-called "Digital WUR" from Unwired Tools. The NA version is not much more than a rebuilt WUR, and personally an option that I find very attractive.
Regarding the ignition components, I believe PET confirms that the ignition unit itself is the same regardless of market (US vs. ROW), but I will double verify that this evening. Regarding the ignition distributor, I've confirmed that there are definitely different part numbers between ROW & US models, so you will definitely want to find a ROW distributor from somewhere in Europe. If for any reason, you can't find one, then the rebuilt US version I have could be recurved, but I think it would be best to find a ROW version, and I suspect probably not too hard. You could probably get both units from the same donor car if you find someone breaking a ROW car. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Tue Jan 05, 2010 6:06 am Post subject: |
I´m thinking about doing it to my n/a me to. Its not so fun to adjust them all the time (which you have to when your engine spends alot of time between 4500 and 6000rpm at the track). And the distributor is getting a bit sploppy. What i heard to be the easiest way is to get hold of a distributor and then take ignition module plus wiring from a car (an old saab for example which is common here) at the scrap. The distributor is found on later 924s. _________________ 1980 924 Turbo
reilly525i
Joined: 07 Nov 2009 Posts: 222 Location: southern california
Posted: Tue Jan 05, 2010 6:13 am Post subject: |
I tell you what. if you guys arent going to go for that distributor I will ( if you dont mind ). that is if its compatible? I have an 80 n/a. what do you think ideola? _________________ "There are no kings inside the gates of Eden"
80 n/a 924.
76 alfa romeo spider
e34 525i.
xj6 vanden plas
vintage Sunbeam 6 speed bicycle |
Posted: Tue Jan 05, 2010 6:21 am Post subject: |
Yes, it is compatible, it's for a 1979-1980 NA, US market. It's up for grabs  _________________ erstwhile owner of just about every 924 variant ever made |
rkn
Posted: Tue Jan 05, 2010 6:27 am Post subject: |
About 6 months ago I was offered a points distributor with a contactless lumenition PMA 50 modification. It had been taken from a '76 924 Euro.
http://www.lumenition.com/new/main.php/optron/
Don't know if the guy still has it, but PM me if you are interested and I will send his contact info.
It's located in Denmark. _________________ 1980 924NA ROW |
dreamgts
Posted: Tue Jan 05, 2010 7:18 am Post subject: Points to Electronic ignition swap |
reilly525i wrote: | I tell you what. if you guys arent going to go for that distributor I will ( if you dont mind ). that is if its compatible? I have an 80 n/a. what do you think ideola? |
Im taking ideola's advise on this one and since theres a doubt if its compatable i will take some time to find one which is. I dont mind at all my friend.
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
john h
Posted: Tue Jan 05, 2010 10:39 am Post subject: |
The easiest way of changing to electronic ignitionis to swap to a after market unit such as Pertronix's.
I recently did this to my 1979 924 Auto. Which also had points. It was as quick as replacing the points and once done you never have to open the distributor cap again. Sequence is remove distributor cap, remove the points and capacitor , install the electronic module set the gap using the guide supplied and connect two wires - one to the positive side of the coil and the other to the negative side. Put distributor cap backon and it's all go. The Pertronix part you require is a 1847V (or that's what I installed in my car) in New Zealand I paid the local supplier NZ$145 (USD$110)
I also did my Nissan Patrol off roader last year and it was a bit more difficult as I had to machine the distributor shaft which required the distributor to be removed. _________________ Remember a Porsche is not just for Christmas,
Ozzie
Posted: Tue Jan 05, 2010 9:25 pm Post subject: |
Have you tried these?
My father bought a similar kit for his opel kadett 1964 and the car ran much better with the old points than when converted.
My distributor on my 79na is getting a bit sloppy, do you know how god the clearances must be for a hall system like this ? _________________ 1980 924 Turbo
Nobbi
Posted: Tue Jan 05, 2010 10:07 pm Post subject: |
As John says, but i do the same to my 4/1977 NA with a Ignitor set-up. Takes 20 min.and yourè done.
Check: www.ignitor.de
Nobbi  _________________ NA 924 - april/1977- 4-speed-audi gearbox.
500.000 km with fun.....and new toy:Porsche 944 S2 Cabriolet.Other car Daimler c-class cabby,brandnew..Plus : DEUTZ 4005 tractor Built 1969 |
Ozzie
Posted: Tue Jan 05, 2010 10:18 pm Post subject: |
I have put similar systems in other cars with good results.
http://www.holdengemini.info/site_images/cars/holden_gemini_te_large.jpg
You have to tune it after, not a straight drop in and go. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
dreamgts
Posted: Tue Jan 05, 2010 10:32 pm Post subject: Points to Electronic ignition swap |
ideola wrote: | EFI (electronic fuel injection) is not a trivial conversion. I am working on developing some bolt-on components, including a fuel rail, and crank trigger wheel for electronic ignition, and I've found a source for flow-matched injectors. However, there's more to it than that...you still need to find an ECU, either an open source Megasquirt approach, or an aftermarket product like 034Motorsports, DTA Fast, VEMS, or a number of others. A thorough read of the Engine Management section of the Performance Upgrades thread would be a good idea, as it will help you understand what's involved with an EFI conversion, point you to several examples here, so you can judge for yourself if EFI is a path you want to go down.
Regarding the ignition components, I believe PET confirms that the ignition unit itself is the same regardless of market (US vs. ROW), but I will double verify that this evening. Regarding the ignition distributor, I've confirmed that there are definitely different part numbers between ROW & US models, so you will definitely want to find a ROW distributor from somewhere in Europe. If for any reason, you can't find one, then the rebuilt US version I have could be recurved, but I think it would be best to find a ROW version, and I suspect probably not too hard. You could probably get both units from the same donor car if you find someone breaking a ROW car. |
After discussing my options regarding ignition system and fuel system (on another thread) obtained from this forum with my mech, he or else we have decided on what I am describing as a fuel system with ITB's and electronic injectors (Iv seen some on the forum) and a DTA system. My mech states that with this system present fuel and ignition systems will be totally removed, fuel supply seems to be replaced by an inlet manifold with throttel bodies were injectors will be placed, while igniton will be replaaced by some sort of electronic device which eliminates even the distibutor, he explained to me that a distibutor type unit will be feeding each spark plug and therefore 4 of these are needed 1 for each plug, He showed me somthing used on A Japanese type vehilce so that i could understand the system. The system seems to generate the right spark at the exact right time and can also be programmed. Is anyone here familiar with these 2 systems. Any comments or advice. I must state that I am not that much in mechanics and therefore please be patient with me as already been done . i thank those who have been patient and answered my questions in much detail. Which info is regarded and precious if sure even by other members of the forum.
Thanks
dreamgt _________________ 2 PORSCHE 924 (CURRENT PROJECTS)
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
