Gonna be busy..
Joes924
PostPosted: Wed May 29, 2002 11:30 am    Post subject: Reply with quote
Comon sunshine....
Ill have the head ready by the 1st with the header. The header is a bursche I picked it up for $15.00 some dummy before me tried to get it off without undoen the motor mount I think it was any way he couldnt get it off even though he dented in the 4 th tube in 2 places up top by the head tryin to get it off- I also had to hacksaw the end off so I talked to the welder today showed it to him and my idea was to put some weld on there and id just grind the dent off from the inside then have him weld on the new collector/reducer,he said how about we heat up that dent till its glowen then just push it out I said ok.. no ceramic coating just heat paint for now I think red I got those tayler plug boot protectors for heat.
Then the head is ready just got to put the valves in there [made all my own gaskets except the head gasket just traced the old ones and wala,the intake was place on the head side &I used my dremel to get the fit just right up against the side of the port for a perfect fit] ..
then right after I have it runnen with the head project [cam,porting,header]Ill jump out back &put in the clutch kit and rebuild
the torque tube and swap out the tranny.
I did the clutch last year it was cheap I feel so bad about what I have to say, I used a used clutch disc and the same press. plate and throw out bearing ,pilot bearing. I now have a new kit I picked up on e-bay. afford .. Ill do the head tjis weekend or next weekend.I want to clean up the tops of the pistons real well and paint up the rest of the block where the intake used to be. _________________
Joe D.from Denver Colorado residing in Oregon
RTFAQ
[ This Message was edited by: joes924 on 2002-05-30 11:51 ]
Joes924
PostPosted: Fri May 31, 2002 6:37 am    Post subject: Reply with quote
1.Headers at the welder,till friday
2.head gasket & new oil seals be here Friday
3.Lost 1 valve lock 6 day waite so Ill use one from the car.
4.Pick up Mr. gasket header gasket & assorted bolts Friday
5.Ill start Friday after my game setting the valves prob. work all night and saterday also.
Im haven fun driven around thinken about this project though..kind a
Joes924
PostPosted: Sat Jun 01, 2002 11:47 am    Post subject: Reply with quote
Friday night 6:48 pm.Ready to start.
check it out
http://home.attbi.com/~joedanka/May924/start.JPG
marky522
PostPosted: Sat Jun 01, 2002 11:50 am    Post subject: Reply with quote
I dont even want to know what you are going to use that for.
Mark
Joes924
PostPosted: Sat Jun 01, 2002 3:34 pm    Post subject: Reply with quote
10:35 its off
check it out.. Mark its late for you no..
http://home.attbi.com/~joedanka/May924/off.JPG
Joes924
PostPosted: Sun Jun 02, 2002 12:10 pm    Post subject: Reply with quote
Worked 18 straight hours and its done ..
fired right up dont have much iol pressure oil levels low..fill that & I still have to finish adjusten valves.
http://home.attbi.com/~joedanka/May924/one.JPG
http://home.attbi.com/~joedanka/May924/two.JPG
http://home.attbi.com/~joedanka/May924/three.JPG
