firemn131
Joined: 16 Jul 2008 Posts: 57 Location: Lusby, maryland
Posted: Sat Sep 05, 2009 12:39 pm Post subject: Turn signal relay buzz |
Hey gang. I'm back!!!!
I drove car to work, 65 miles. as I turning it off the turn signal relay started buzzing.
I removed relay. Bought another, same problem. Turns signals and flashers work as they are supposed to but this buzz wont go away.
It is only buzzing when car is off.
I think that relay is getting energized when it is not supposed to. {DUH}
Does this sound like an ignition switch?
What would redirect current to the relay after ignition off?
Thanks for the help.
John _________________ 1987 924S Daily driver 64 miles each way to work.
2001 F-150 my back up
1970 Mercury Cougar XR7 The Muscle. |
edredas
Posted: Sat Sep 05, 2009 2:30 pm Post subject: |
Try unplugging the hazard light switch and see if it makes it go away... _________________ '84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver |
