Educate me on crankcase/camcover breathing
PostPosted: Sun Jun 21, 2009 8:34 pm    Post subject: Educate me on crankcase/camcover breathing Reply with quote
EFI.. Turbocharged 924
What should i do with the crankcase breather?...does it just pipe straight up into the intake manifold?.. PCV valve?..is that what prevents boost pressurising the block?
Also the dizzy has been removed (EDIS4) and so i have the option of a blank plate or putting some sort of breather....is it necessary...or helpful?
Almost have finished my first complete engine rebuild...and its loookiing sweeeetttt
1979 NA
my Porsches Arse!!!
PostPosted: Mon Jun 22, 2009 12:16 am    Post subject: Reply with quote
The factory 931 breather system includes 2 air-oil seperators - one for the
crankcase (#1) and one for the turbo oil drain line (#5) -
The air return line (for both 924NA and 931) attaches upstream of the manifold
and TB. -Either at the airbox or chamber after the airbox for 924NA, and at the
airbox for 931. Either way it goes upstream of the throttle body, and downstream
of the filter element.
The factory 931 setup does not use a PCV valve.
PostPosted: Mon Jun 22, 2009 10:11 pm    Post subject: Reply with quote
Smoothie, why doesn't that diagram depict the head breather update for the 931???
Scorpio, what you'll want to do is to purchase or fabricate an air-oil separator. The big line from the crank case should plumb directly into the air oil separator. Then you will need an oil line to plumb from the bottom of the a-o separator back to the second port on your oil pan (the one just above the drain plug). The topmost port of the separator should plumb into the intake path post filter but pre-TB.
As noted above, the 931 also had a "breather update". The funky block off plate on the LHS of the head (just below the oil filler cap facing the intake manifold) was modified on 931's with an elbow, which you can see about dead center in this early photo of my UWB engine bay:
Some of the early 931s did not have this, but my UWB was a 1980 series 1, and came stock with it. I've seen one 931 head that didn't even have the port opening on the side of the head, but most of the 931s I've seen in person already had the breather update. I can't recall off the top of my head where it plumbs back into the intake tract, but IIRC the metal tube you see in the photo above either connects to the recirculation valve or somewhere along the charge air path prior to the turbo.
For your application, you might want to consider just welding up your ignition distributor housing because there have been multiple reports of the block off plates not sealing correctly and leaking oil from the back of the head. Here's mine:
Rather than plumbing a breather port there, if you take a close look at your valve cover, you will see on the part to which the filler cap attaches, facing the intake, there is enough room there to weld on a small nipple suitable for a head breather, which is how it was done on this GTS:
Note in the photo above, the GTS doesn't use the 931-style breather update adapter on the head. Also, the issue you may get into with an EFI conversion is that the fuel rail will almost certainly interfere with the elbow on the breather update adapter, which is why I won't be using it when I build the motor for the UWB. Since I've welded my cam cover shut (due to the dry sump), I will either plumb a fitting on the sealed filler cap, or do it as depicted above on the GTS engine.
At any rate, from this location, I think you could probably just tee back into the pre-air-oil-separator line; you would probably want to install a one-way valve in that line to prevent crankcase pressure from coming back into the head.
PostPosted: Mon Jun 22, 2009 11:30 pm    Post subject: Reply with quote
ok thanks Dan and smoothie i think ive got it..
so basically
1)
crank case breather -------->T junction-----> oil air separator
oil air separator to A) One way valve AND B)lower drain to oil pan
One way valve ---> air intake pre throttle body
2) Cam shaft breather (either in dizzy block off plate or above injector1 block off plate)-----> T junction as above
Questions
1) How necessary is a breather in the head?and what size breathing hose is required..ie just how much air needs to be vented?
2) Where do i get a one way valve/specs needed?
3) I think my sump only has the one plug and no other inlet/outlet? so just weld a return bung in or just let the oil separator collect the oil them empty when full?
4)If youve welded your cam cover shut how on earth do you get to your injectors...im guessing you just meant the breather plate openine?
5) why not just vent the air to atmo if its oil free after the air oil separator?
1979 NA
my Porsches Arse!!!
PostPosted: Mon Jun 22, 2009 11:44 pm    Post subject: Reply with quote
I've welded the oil filler cap (at bass gt's recommendation) to prevent any air leakage in the crankcase, ideally maintaining as a high a vacuum as possible due to the dry sump. It will still be bolted on as normal:
As for venting air to atmo, you could do that, but don't tell Nobbi or any of his environmentalist friends
Chrenan
PostPosted: Tue Jun 23, 2009 12:50 am    Post subject: Reply with quote
I run this breather can on my 924:
http://www.saikoumichi.com/951_page.htm
Its for a 951, but the 3/4 hose barbs work for a 924 as well. It goes between the crankcase breather and the intake tract. I empty it every couple of months, a little bit of liquid comes out, not a whole lot. There is no oil in my intake tract, it catches everything coming out of the crankcase breather hole.
PostPosted: Sun Aug 02, 2009 2:50 am    Post subject: Reply with quote
I have a new Monza Catch Can...unfortunately it has no baffel material inside it. (to separate the oil and air)....its good quality alloy with all the appropriate connections......
Ive read of people filling There catch cans with Stainless steel scouring cloths to act as a oil/air separator/condensor......could this be used in my Monza?
1979 NA
my Porsches Arse!!!
PostPosted: Sun Aug 02, 2009 1:52 pm    Post subject: Reply with quote
What does the manufacturer recommend?
If the oil vapour entry is directed to swirl around the inside wall of the can, maybe you don't need/want to add anything.
Got a pic of it?
PostPosted: Sun Aug 02, 2009 8:47 pm    Post subject: Reply with quote
Got a pic of it?
same as this one....can be used as a radiator overflow bottle...the two entry and exit pipes sit flush to the inside surface of the can( no baffling or internal down pipe such as in Chrenans model)......i can unscrew the lid and pop some metal scourers inside..nice and cheap
http://cgi.ebay.com.au/Oil-Catch-Can-Radiator-Overflow-Bottle-Alloy-Sqre-BLU_W0QQitemZ260450681999QQcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item3ca412048f&_trksid=p4634.c0.m14.l1262
1979 NA
my Porsches Arse!!!
tuurbo
PostPosted: Mon Aug 03, 2009 12:40 am    Post subject: Reply with quote
Scorp far be it from me to educate you on the crankcase breathing apparatus - the other guys here know way more than me.
But I gotta emphasize, that piece that Dan is pointing out, the piece going from the head down to I think the oil drain off from the turbo, was actually helpful in that these tend to let the turbo drain itself of oil much better, I think. It's an upgrade worthy of the name upgrade.
1980 924 turbo, MSD, Meth. Inj, otherwise stock.
PostPosted: Mon Aug 03, 2009 12:54 am    Post subject: Reply with quote
Yes, the diagram I posted above is of one of the earlier versions. It shows crankcase breathing Tee'd into the turbo drain breather. They found this was causing water vapour to accumulate in the turbo drain breather line and turbo drain line (which when mixed with oil and oil vapour formed sludge). This slowed and/or eventually blocked turbo oil drainage. The final design, 2 or 3 versions later seperated the two breather systems by doing away with the T (actually more of a Y in real life) and connecting the turbo oil drain breather to the cyl head instead.
Rocco R16V
PostPosted: Mon Aug 03, 2009 7:16 am    Post subject: Reply with quote
The reason to plumb into the intake is for some (however small) amount of vacuum to help draw the gases out of the crankcase rather than let them build pressure. in some high boost apps they will use a vucuum pump to apply more vacuum to the cc to help in ring sealing.
There is one solution muscle cars use, is to use one of these check valves plumbed into the exhaust. this way the dirty air is drawn out but not into the intake.
http://www.summitracing.com/parts/MOR-97800/
"Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan
PostPosted: Tue Aug 11, 2009 5:22 pm    Post subject: Reply with quote
1) Does anyone see a problem with the following....?
2)Any requirements for catch can elevation?
3)I was thinking of sticking in an internal wall with holes drilled in to force oil air mix through more scourer....waste of time?
4)Is there a point to a cam cover breather on a newly rebuilt engine (turbocharged)....would i want vacuum if there is no blowby in the cam cover section?
5) would vapours from crankcase breather go up through pipe into cam cover?..or is that stock metal T/Y pipe venturi?
1979 NA
my Porsches Arse!!!
PostPosted: Tue Aug 11, 2009 11:45 pm    Post subject: Reply with quote
I do believe the stock pipe is a venturi. It would be best to have a one-way check valve to prevent crankcase blowby from going back into the head. Elevation wise, I would mimic the factory 931 setup, which has the catch can mounted to the LHS frame rail on a bracket that puts the top of the can just about level with the lower (inside) edge of the shock tower.
