Small Fuel Leak on a 1981 931
SaxJazz12
PostPosted: Sat May 23, 2009 3:54 pm    Post subject: Small Fuel Leak on a 1981 931 Reply with quote
Hello!
I've been noticing that my car has been leaking a very small amount of fuel. It will form a a drip on the in-tank fuel pump gasket, then fall to the ground. The connection seems tight! I set out a piece of cardboard to check the amount and it is not a lot, but of course this is still a definite concern. Do I need to replace the in-tank fuel pump?
Thanks
1997 Saturn SW2
PostPosted: Sat May 23, 2009 5:45 pm    Post subject: Reply with quote
Replace the gasket, when the tank is empty!
