rust
ltgland
PostPosted: Mon May 20, 2002 4:31 am    Post subject: Reply with quote
eek. I found a rusthole in my left wheelwell, near the strut (back from it, toward the passenger compartment, maybe 5 cm away). Is this a loard bearing spot? Also, is there anything I can spray inside that well without having to take the side off?
PostPosted: Mon May 20, 2002 5:51 am    Post subject: Reply with quote
spay some anti rust stuff then i would suggest getting that fixed before it speads too much
carnut280
PostPosted: Mon May 20, 2002 12:57 pm    Post subject: Reply with quote
anyone know if putting undercoating on it after it has been thouroughly cleaned will prevent rust? (the wheel wells)
PostPosted: Mon May 20, 2002 10:10 pm    Post subject: Reply with quote
yes it will prevent rust but before you put on undercoating primer it then put on the undercoating
Cbass
PostPosted: Tue May 21, 2002 5:14 am    Post subject: Reply with quote
This all depends on your definition of thoroughly cleaned. If you mean you first went over everything with a putty knife, then acetone, a wire brush, cut away any rust, sanded down anything that wasn't shiny, and then primered it, yeup.
