coconutcowboy Guest
Posted: Sun May 19, 2002 7:32 am Post subject: |
having problems with my frequency valve and the warm start pressure reducing valve/solenoid. also are there other cars that cary same or slightly higher performance injectors.
also any other cars I could get the cold start valve and aux air reg form ? close match? Any other cars with same part or close match out there other than Porsche 924?
also what about using a load sensing warm up regulator from an audi.
Can I use my 78 metering head and a few repacement lines to properly setup the system? What cars can I get a 110mm airflow meter that moves up and not down that will fitmy airbox?
any source for euro pistons and cams?
Will a audi 5000 throttlebody help my engine breathe better.
Can a 924 turbo intake be used on a NA engine with any performance gains?
I already bought a head gasket , phosphore bronze guides and teflon seals and new valves.head gasket part # 931 104 337 3. will there be piston to valve interference?
Any info especially year make model and oem part #'s would be appreciated
Sean Ross
larso Guest
Posted: Sun May 19, 2002 4:00 pm Post subject: |
Hi, you can get the cold start injectors off volvos, 200 series. They use bosch and have the exact same CS injector. I'm guessing a lot of audis use it too, haven't seen an audi for a while. Turbo headgasket should not cause any interference, and turbo manifold will not bolt up since the head stud spacing are different.
