tuurbo
Posted: Mon Apr 27, 2009 11:20 pm Post subject: How to get it up on a dirt floor |
Would a 4' x 8' sheet of 1" thick plywood on the floor of a dirt floor garage be safe enough to use jack stands? Or will they just bust right through with the weight of the car? Maybe I should try levitation? Any suggestions? _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
DOCO
Joined: 04 Aug 2006 Posts: 1111 Location: Keswick Ontario Canada
Posted: Mon Apr 27, 2009 11:23 pm Post subject: |
put down the sheet of plywood,and then use patio slabs.i use patio slabs on my drive way,its tar but it stops sinking in _________________ Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
dpw928
Posted: Mon Apr 27, 2009 11:32 pm Post subject: |
How flat and how packed is the dirt? Is it moist? On the plywood, they normally make 3/4" exterior and interior grades and 1 1/8" interior grades only. Make sure yours is exterior grade. If you use interior grade, spilled coolant or water will cause the plywood to delaminate. If the floor isn't flat, a 1.25" buildup is recommended to keep it from flexing/warping when weight is applied.
78 928 5 sp Silver
78 928 AT Euro Black |
Posted: Tue Apr 28, 2009 12:08 am Post subject: |
Concentrate? _________________ Toofah King Bad
924guy
Posted: Tue Apr 28, 2009 12:26 am Post subject: |
| Rasta Monsta wrote: | | Concentrate? |
poof, coffee all over the monitor........
get two 2x6x8's , sink em in under the plywood where the jack stands will be...dont get under the car until you are 200% its completly stable and safe to do so... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Posted: Tue Apr 28, 2009 5:59 am Post subject: |
These are all good suggestions, I would just add, maybe put a tire/rim or two under the car, just in case. _________________ [This Space For Rent] |
BionicBalls
Joined: 05 Jan 2009 Posts: 642 Location: Charlotte, NC
Posted: Tue Apr 28, 2009 7:01 am Post subject: |
Take two Viagra and call me in the morning. _________________ 1980 924 NA
1982 931 |
Posted: Tue Apr 28, 2009 7:25 am Post subject: |
| If you cant get it up on a dirt floor maybe your girlfriend is too dirty for you. |
