windshield washer problems
Scorpion
PostPosted: Tue May 14, 2002 11:23 am    Post subject: Reply with quote
Before I go and buy a new wiper moter can anyone help with this problem. When the wiper motor is plugged in under the hood it will not turn off via the switch lever by the steering wheel. I can still change the speed of the wipers and if held correctly I can stop the wiper with the lever but this requires a very steady hand and makes shifting impossible. I just changed the lever assembly yesterday and the problem persists, any help would be greatly appreciated.
[ This Message was edited by: Scorpion on 2002-05-14 11:24 ]
JvGinPDX
PostPosted: Tue May 14, 2002 12:03 pm    Post subject: Reply with quote
I think your problem is in the wiper switch. Possibly a dirty contact. Maybe a short. Your motor works, a new one would act the same way.
marky522
PostPosted: Tue May 14, 2002 12:38 pm    Post subject: Reply with quote
It could be a bad relay.
Mark
Scorpion
PostPosted: Tue May 14, 2002 12:51 pm    Post subject: Reply with quote
thanks for the replies I will check it out.
