So I decided to try and start my 924 today...
JtWo
PostPosted: Tue Jan 20, 2009 12:58 pm    Post subject: So I decided to try and start my 924 today... Reply with quote
after 9 years! New battery, fresh gas, and still no start. Any ideas?
I'll post a video as soon as youtube approves it.
-Jonathan
1977 Porshe 924
Red w/ blue ghost flames
Me wheel gap hating
JtWo
PostPosted: Tue Jan 20, 2009 1:09 pm    Post subject: Reply with quote
http://www.youtube.com/watch?v=QKS9_zWBclM
-Jonathan
1977 Porshe 924
Me wheel gap hating
Ozzie
PostPosted: Tue Jan 20, 2009 1:40 pm    Post subject: Reply with quote
3 things to make a car run
1 spark at the correct time
2 fuel
3 air
Assuming you dont have a birds nest blocking the air induction I'd guess its 1 or 2.
That will be $500. I accept Paypal.
Its AUTO and its BLACK
Montego Black on black/red
CorsePerVita
PostPosted: Tue Jan 20, 2009 5:29 pm    Post subject: Reply with quote
As ozzie said:
Spark, Fuel, Air.
You've got power to the battery. You need to make sure your plugs are sparking. You also need to check and make sure you are getting fuel. It's a 924 so the fuel pump should be turning on, make sure you can even hear it come on.
Could be a multitude of things if it sat for 9 years. Start with the basics. Make sure injectors are getting fuel, make sure sparkplugs are getting spark... etc.
- 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
PostPosted: Tue Jan 20, 2009 11:43 pm    Post subject: Reply with quote
RECOMMENDED READING
Although that thread is specific to a turbo car, you can just ignore the turbo-specific information. The same basic premise applies.
Required tools:
Multi-meter
Spark tester
Haynes manual
CIS pressure tester (available from JC Whitney for $60)
4" of 16 gauge wire and two spade terminals to make a fuel pump relay jumper
The usual assortment of screw drivers, metric wrenches, and a 3mm allen wrench
This isn't a comprehensive diagnostic approach (you'll find that in Haynes), but this is the basic approach I would take to rule out one variable at a time.
Validate spark first. Get a spark tester and put it inline between the coil and dizzy, make sure you get spark to the dizzy. Then check each spark plug individually to make sure you have it at all four. If that checks out, move on to fuel. Consider replacing the distributor cap, rotor, coil, plugs, and plug wires.
For fuel, start at the back of the system. Make sure you have 12v at the fuel pump. Make sure the pump is running. Then move forward into the engine bay. Replace the fuel filter. Verify that you have fuel getting to the fuel distributor. Verify that you have fuel flowing to and thru each of the injectors. Check injector spray pattern. Run a complete CIS system test using the aforementioned pressure tester.
Report back with results and ask questions here
PostPosted: Wed Jan 21, 2009 6:59 am    Post subject: Reply with quote
Thats some vid. its kind of dark dont you think.
to see if your getting fuel pull an injector & line out of the head out
they just pull out with a pair of channel locks gripping the injevtor base tightly, then place it in a bucket and take the boot off the big round thing ( that house the sensor plate now with the key on and the fuel pump running pull up on the sensor plate at this time the injector should squirt out fuel.
StienbargerR
PostPosted: Wed Jan 21, 2009 2:07 pm    Post subject: Reply with quote
Also make sure that you've got all the timing right. I had trouble with my car not starting when I first got it...turned out I had the spark plug wires out of order on the Dizzy
1978 924 NA
-250lb lowering springs, Euro Pistons
PostPosted: Thu Jan 22, 2009 11:20 am    Post subject: Reply with quote
While cranking is the camshaft pulley turning?
