Paul Guest
Posted: Fri May 03, 2002 11:38 am Post subject: |
I must be getting old, but the 205-55x16's are a bear to turn at low speeds, I've worn out two steering shaft U joints over the years!
Has anyone figured out how to install the 924S power steering rack and pump on a 931?
marky522 Guest
Posted: Fri May 03, 2002 12:44 pm Post subject: |
| Or a 81 924!!! |
kevrl Guest
Posted: Fri May 03, 2002 9:44 pm Post subject: |
I'd also be interested in this, so if anyone figures it out, post it here and let us know.
As far as I can see, the rack should probably fit straight on (would you need an 'S' crossmember? - or are they the same ?), the real issue would be where to mount the pump and get a drive belt to it ?
Kevin |
Paul Guest
Posted: Sat May 04, 2002 10:34 pm Post subject: |
| I'm guessing I could remove the A/C compressor and mount the P/S pump in its place, but even in Wisconsin, the summers get very hot.... |
numbers Guest
Posted: Tue May 07, 2002 7:28 am Post subject: |
| Yeah, and these cars have really crapie interior ventilation. |
friskynibbles Guest
Posted: Tue May 07, 2002 8:12 am Post subject: |
doesn't my 931 have power steering? it feels like it does...
Smoothie Guest
Posted: Tue May 07, 2002 8:53 am Post subject: |
| Just keep them front tires pumped up and pump a little iron now and then. |
