Converting to hood gas struts
Martijnus
PostPosted: Thu Oct 02, 2008 1:25 am    Post subject: Converting to hood gas struts Reply with quote
I just ordered the stock porsche parts to convert to gas struts for the hood... I seriously haven't got any idea how and where the stuff goes, so I hope someone has a pic.
Found this thread.
http://www.924board.org/viewtopic.php?t=5311
Now I'm quite shocked by the fact that I'll get problems with my battery.
Am I right if I don't need the stand anymore when I convert to struts?
Do I need to weld the mounting stuff to my car, or is it bolt on?
BTW...stuff I ordered was from the pet parts list, couldn't see much about fitting.
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
PostPosted: Thu Oct 02, 2008 2:02 am    Post subject: Reply with quote
I just updated my pic links here - http://www.924board.org/viewtopic.php?t=21147&start=17
Martijnus
PostPosted: Thu Oct 02, 2008 2:43 am    Post subject: Reply with quote
thanks!
As far as I can see, the mounts on the hood itself are welded?
Can't see much of the lower mounts, but I guess those are welded too.
Don't feel much like welding, but I could first give it a try with epoxy adhesive, if it works, it can be permanented with welds.
Hope I don't make it a rust bucket by welding the stuff....
PostPosted: Thu Oct 02, 2008 6:52 am    Post subject: Reply with quote
Yes, they're all welded - spot welds (2 on each of the three "tangs" of the lower mounts, and 2 spot welds on each of the 2 tangs of each upper mount).
I'd give the epoxy by itself a no...I'd at least go with either a combination of sheet metal screw and epoxy, or rivet and epoxy. "Glue it and screw it" - just like any of the many forms of quality woodworking.
Martijnus
PostPosted: Thu Oct 02, 2008 7:49 am    Post subject: Reply with quote
Any ideas how to figure out the position where the mounts should go?
On smoothies pics I can estimate the hood ones...but the lower ones? Just see what the best place is when the hood is up and the struts at their longest?
Do I still need the hood stand?
PostPosted: Thu Oct 02, 2008 10:01 am    Post subject: Reply with quote
3 more pics start here, showing the positioning -
http://www.flickr.com/photos/9754161@N02/2905334237/in/set-72157600685471748/
