Bumper
Newgoalie27
PostPosted: Sun Sep 28, 2008 11:12 pm    Post subject: Bumper Reply with quote
Ok so
My car is missing its drivers side rubber bumper part and I think I need a new one since it was gone before I got the car
Any ideas where I could find one and the brackets that hold it on?
My to do list:
1965 Mustang fastback
1977 Porsche 924 NA no turbo
Hey if I get my brakes working and fix the Lower rocker panel and the drivers side damage from when the guy who had it before me slid off the road this could be my first car
JayZzzz4
PostPosted: Mon Sep 29, 2008 11:24 pm    Post subject: Reply with quote
There's a few on ebay that I saw a little while ago. As for the brackets, I'm not sure, you might have to make something or use a butterfly wall anchor.
[/img]
White 1987 Porsche 924S manual
StienbargerR
PostPosted: Wed Oct 01, 2008 3:20 am    Post subject: Reply with quote
There isnt really a bracket. There are two studs that come out of the back of the "bumperette" and you just bolt it on.
Ryan
1978 924 NA
-250lb lowering springs, Euro Pistons
Newgoalie27
PostPosted: Wed Oct 01, 2008 11:51 am    Post subject: Reply with quote
Well it looks like there was some sort of bracket on the outside
Maybe its a piece of sheet metal on the rubber part that the bolt bolts into?
My to do list:
924guy
PostPosted: Wed Oct 01, 2008 10:17 pm    Post subject: Reply with quote
no bracket... the rubber has a stud attached to a small washer like plate molded into it, there is also a smallish depression molded in that lines up to the "pin" on the bumper itself. The studs rust out, the rubber decays, and eventually, the pieces separate.
I have successfully repaired these by carving out the bad rubber, sinking a new stud and filling with flexible epoxy (i dont remember which type or brand I used, but it was regular parts store stuff. ) just had to be carefull not to overtighten upon re-installation as to not pull the new stud out, and of course to let the epoxy dry several days.
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
