timing marks
944cabby
PostPosted: Tue Sep 23, 2008 2:54 am    Post subject: timing marks Reply with quote
I've spent the weekend trying to get my '77 924 to fire up with no success and late yesterday to top it all the timing belt snapped.
I have a new belt ready to fit and the upper timing belt pulley mark matches up with the pointer on the rocker cover.
The notch on the V belt pulley lines up eith the pointer on the oil pump and the timing mark on the flywheel ("0"?) is visible through the housing.
Does this sound all correct before i go ahead and tighten everything up as the previous owner had it set quite different - the v-belt pulley was marked in a much different place and no marks were visible on the flywheel housing.
Any advice is much appreciated.
http://img262.imageshack.us/my.php?image=timingmarkskp2.jpg
1977 martini 924
1983 met claret 924 lux (sold)
1979 burgundy 924 (broke it for spares)
datatrain
PostPosted: Tue Sep 23, 2008 3:41 am    Post subject: set up Reply with quote
That's how my 78 924na is set up.
'78 924 NA with Collector plate
33 year old car, with me for 21 yrs
Mint '92 318i BMW
Near mint '98 Buick LeSabre
VE7HFR
Rich H
PostPosted: Tue Sep 23, 2008 3:43 am    Post subject: Reply with quote
Sounds good!
Nick on the back of the crank pulley lines up with the pointer on the oil pump.
Bot on the back of the pulley lines up with the pointer on the cam cover. Make sure that the words on the pulley face backwards towards the block, as it is possible to fit the pulley and the flywheel incorrectly...
944cabby
PostPosted: Tue Sep 23, 2008 3:56 am    Post subject: Reply with quote
Thanks guys!
1977 martini 924
944cabby
PostPosted: Tue Sep 23, 2008 6:49 am    Post subject: Reply with quote
Well, she wouldn't fire up after - i checked the plugs and they have a good spark - fuel seems to be getting through but i'll test the injectors tomorrow.
1977 martini 924
Ozzie
PostPosted: Tue Sep 23, 2008 7:15 am    Post subject: Reply with quote
with the oil pump pulley, flywheel and cam pulley lined up did you check the dissy?
The rotor should have been pointing to the lead for no 1 spark plug.
Its AUTO and its BLACK
Montego Black on black/red
944cabby
PostPosted: Tue Sep 23, 2008 8:45 pm    Post subject: Reply with quote
Still won't start - i've checked the injectors and there's plenty of fuel going to the cold start valve on the inlet manifold but nothing coming out of the other 4 injectors - i pulled them all and there's nothing spraying out when you turn the key in the ignition.
Any ideas chaps?
1977 martini 924
wombat
PostPosted: Tue Sep 23, 2008 8:57 pm    Post subject: Reply with quote
vacuum leak. it sounds like, I must admit that I have never checked the cold start valve injector when I have had one so I am unsure of the situation with this one. BUT... if you are getting fuel delivered to the fuel distributor (which you must be if it is coming out of the CSV) but none to the injectors then vacuum is the place to be bro. I have just come out of a monster ordeal with vac on my 77. every time I worked on it I had another one, it would be running fine then wouldnt start, fine then, no start, etc etc. I did all the easy to get to vac hoses early on, then I repaired the fuel distributor boot, then all the hard to get at and smaller (unnoticed) vac lines. then I replaced the inlet boot and while I was at it installed a new distributor boot as I figured that while I was getting the other one I should do it as my repair on it was a little dicey. Good luck the vac system on this car has given me nightmares hopefully it is sorted for another 30 years now.
1977 924 2.0 Auto
Ozzie
PostPosted: Tue Sep 23, 2008 9:53 pm    Post subject: Reply with quote
did you lift the air metering plate when you checked the injectors?
944cabby
PostPosted: Wed Sep 24, 2008 1:42 am    Post subject: Reply with quote
Checked all the injectors and they're squirting fuel ok - she backfired slightly on occassion and smoke came through the airbox although she wouldn't fire up properly.
Ozzie should the mark on the rotor line up with the small line on the top of the dizzy as well as pointing to the no1 spark plug (with the points open?)
1977 martini 924
dpw928
PostPosted: Wed Sep 24, 2008 4:06 am    Post subject: Reply with quote
The points should be closed to fire the ignition. Appears it is too far advanced since it's backfiring. Try turning the dstributor clockwise 1/8th of a turn.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
944cabby
PostPosted: Wed Sep 24, 2008 5:04 am    Post subject: Reply with quote
Thanks Dennis, she's just backfired more than it's done before but the battery has died now so it's on charge - fingers crossed for tomorrow.
Does the fuel distributor on the airbox control the amount of petrol going to the injectors - checking the spark plugs they appear very wet so i wonder if too much is being fed through?
Thanks to all for the help.
1977 martini 924
dpw928
PostPosted: Wed Sep 24, 2008 5:56 am    Post subject: Reply with quote
The wet plugs could mean that the ignition firing is way off or you are getting way too much fuel. Is it backfiring into the intake now or is it an afterfire into the exhaust?
If you think it is too much fuel, unplug the cold start valve on the intake plenum and retry starting with the accelerator all the way open.
If the timing is still off, start at square one and check the dot on the cam to make sure it is lined up with the valve cover pointer when the pointer on the oil pump is aligned with the notch on the harmonic balaner. Then check the distributor to make sure the rotor is aligned with the #1 plug wire and the points are closed. Also check the firing order on the remaining plug wires to make sure they are 1 3 4 2 going clockwise on the distributor.
Dennis
81 931 5 sp
78 928 5 sp Silver
944cabby
PostPosted: Wed Sep 24, 2008 6:06 am    Post subject: Reply with quote
Dennis
Sounds like it's from the exhaust although i've also had smoke coming through the air filter box.
1977 martini 924
dpw928
PostPosted: Wed Sep 24, 2008 6:17 am    Post subject: Reply with quote
Try removing the plug from the cold start valve and opening the throttle before trying to start it. It's possible the thermotime switch is bad, and causing continous injection of the cold start valve.
Dennis
81 931 5 sp
78 928 5 sp Silver
