jonny924
Posted: Mon Sep 29, 2008 7:31 am Post subject: 924 hesitates or bogs under load |
1977 924 was sitting a while , installed a new fuel pump , cleaned the meetering block attached to air cleaner and cleaned out injectors -- car will start after 5-6 cranks (delayed start) and idle smooth , when accelerating at idle slight hesitation then revs, when put in gear and off clutch power bogs and engine stumbles, back on clutch idle is fine and will rev with slight hesitation again -- need some help new to older porsches
thanks  |
Posted: Mon Sep 29, 2008 9:31 am Post subject: |
Check the entire intake system (from the air cleaner to the head) for leaks. _________________ White 87 924S "Ghost"
Druman
Joined: 19 Mar 2007 Posts: 419 Location: Middleport, Ohio
Posted: Tue Sep 30, 2008 3:29 am Post subject: |
Vacuum lines too
7osh _________________ 87' 924S non-sunroof (Red) 45K miles
85' 944 "early" NA (Red) 130K miles
PORSCHE pisses excellence... |
Posted: Tue Sep 30, 2008 3:41 am Post subject: |
. . .and for those just tuning in, vacuum lines are part of the "entire intake system."
wombat
Joined: 07 Jun 2008 Posts: 422 Location: Melbourne, Australia
Posted: Tue Sep 30, 2008 9:48 pm Post subject: |
similar symptoms to when I had a small tear in one of my boots in the intake system so check them too all over under and behind, as I didnt pick mine up straight away and this gave me a rather large headache as I couldnt find the problem. _________________ 1977 924 2.0 Auto |
