MikeDanger Guest
Posted: Sat Apr 27, 2002 1:23 pm Post subject: |
for some reason the fuelpump relay is not activating. I took the cover of relay off and watched to see it activate. the car would start if i held it down. Now i guess it coudl be the relay it self, but i have 2 relays, swaped them out and it still didnt work, and both relays worked before.
Also once i held the contact of the relay down to start the car, and after a few minutes it stayed on(the relay).
Where do i start to look?
THanks
Mike 80
931 |
Paul Guest
Posted: Sat Apr 27, 2002 1:39 pm Post subject: |
IMHO since the relay coil is fed by circuit 15 from the ignition switch, it may be the problem. The other thing that will keep this relay from closing is the over boost switch or its wiring.
numbers Guest
Posted: Tue Apr 30, 2002 7:11 am Post subject: |
| Yep, if the wire has come off of your overboost switch, you will not get ground to the relay, and it will not energize. |
