Joes924 Guest
Posted: Sat Apr 27, 2002 9:05 am Post subject: |
OK- I heard talk from cam people and need some help so yes Im asken ?
All theve done is reshape the cam for longer duration &lift and took material off the heel of each lobe.If it turns ok dont worry about anything Ive been told,Im thinken For some reason
shims might be needed.What for? Do thay make different v spring collers for the bucket [tappet] might need to be lower or is it higher. Dont have any idea where to get them
though this makes no sence to me Im not goin to go any further and think up stuff to write here about what I think cause it would
take to long &might not make a whatever. So
whats the deal anyone share to me, Im just gonna put it together and if it rotates without binding
set the valves[there shouldnt be a need to check piston height] & start it up.Well of course thats about 2weeks away & I should buy some new things. Can I make my own intake gasket & another ?. Where can I get a
gasket for this header its used an d doesnt have one.Make my own or buy a stock one?
Joes924 Guest
Posted: Tue Apr 30, 2002 2:47 pm Post subject: |
Fine Ill figure it out for myself .
numbers Guest
Posted: Wed May 01, 2002 7:41 am Post subject: |
| Beyond my limited knowledge. |
Smoothie Guest
Posted: Wed May 01, 2002 8:52 am Post subject: |
| Good reply guys. |
Joes924 Guest
Posted: Wed May 01, 2002 11:01 am Post subject: |
Hows denver numbers avalanche crazy huh.
Ill figure it out its pretty basic I think
AppleBit
Smoothie Guest
Posted: Wed May 01, 2002 1:17 pm Post subject: |
| Yeah, you'd think if they took metal off the heel you'll have to raise the tappets to have the valves adjusted correctly. Hopefully there's enough adjustment available there that you won't have to add parts, but who knows? You'll find out soon enough...NBTNDT. |
Joes924 Guest
Posted: Wed May 01, 2002 2:20 pm Post subject: |
Thanks Jon appreiciate it alot &smoothie thanks also whats NBTNDT stand for
Yea Im excited. |
numbers Guest
Posted: Thu May 02, 2002 4:49 am Post subject: |
| Yeah Joe, it Avs fever again. I watched every minute of that game seven. Great game. |
teo
Joined: 07 Sep 2001 Posts: 637 Location: Hungary, Europe
Posted: Thu May 02, 2002 4:57 am Post subject: |
NBTNDT ?
lemme guess: Never Been There, Never Done That?
marky522 Guest
Posted: Thu May 02, 2002 1:17 pm Post subject: |
Dont worry about that Avs fever, IF they make it past the next round the Wings will take care of them!!!!
HE HE HE!!!!
MArk |
Smoothie Guest
Posted: Thu May 02, 2002 2:43 pm Post subject: |
| Close enough... Not been there, not done that. |
Joes924 Guest
Posted: Thu May 02, 2002 3:04 pm Post subject: |
I went out to dinner that night recorded it though had to mother-in-laws birthday they lost tonight though numbers. Wonder If I adjust the valves to the same mm as in Haynes for a stock cam.
924Porsche1979JoeD.
[ This Message was edited by: Joes924 on 2002-05-02 15:05 ] |
Smoothie Guest
Posted: Thu May 02, 2002 4:58 pm Post subject: |
That would seem to be the thing to do. Just be careful - I heard some Haynes books have a mistake in the valve clearance specs. I don't recall specifically what the mistake was though.
[ This Message was edited by: Smoothie on 2002-05-02 17:00 ] |
-nick Guest
Posted: Fri May 03, 2002 5:53 am Post subject: |
Joe-
by how much are they increasing the lift on the cam? that will be the distance you need to make up either with shims or the adjuster screws. although i really don't think the screw is going to be able to make it up. any shop that does cams should be able to get you shims or tell you where to find. although Jay at DST is your best bet.
and yes, you adjust the valve lash back to stock specs. that is a function of the material expansion more than anything. it is independent of the cam profile.
good luck
-nick |
