MrJoshua
Joined: 19 Jul 2008 Posts: 13 Location: MARLBOROUGH,MA
Posted: Fri Aug 01, 2008 11:48 pm Post subject: '77 engine vibration |
it seems i have developed an engine vibration above 2500 rpm, doesnt effect power, or speed. its just annoying. any ideas what might cause this? _________________ MrJoshua
77 porsche 924
79 porsche 924 |
Vince Ponz
Posted: Sat Aug 02, 2008 3:44 am Post subject: |
Motor mount? _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
Vince Ponz
79 931 Euro stock
88 924S SE
Posted: Sat Aug 02, 2008 4:06 am Post subject: |
Motor mount? _________________ "..it's made in Germany. You know the Germans always make good stuff."
MrJoshua
Posted: Sat Aug 02, 2008 4:08 am Post subject: hmmmmmmmm |
if the motor mount was gone would i have excessive engine movement during acceleration? the air cleaner doesnt move much, ( i can see it under the cowl induction) _________________ MrJoshua
77 porsche 924
79 porsche 924 |
bass gt
Joined: 02 Dec 2004 Posts: 971 Location: Johannesburg for now!!
Posted: Sat Aug 02, 2008 4:22 am Post subject: |
Not nescessarily. The exhaust side mount has a spring inside that fails. But you can't tell by looking at it. You need to pull it out, and then you can see the failure. _________________ Front Wheel Drive is the Devil's work. |
Posted: Sat Aug 02, 2008 4:52 am Post subject: |
Could be mixture as well. . .I just reduced an annoying vibration by richening up the mix a touch. _________________ Toofah King Bad
Chrenan
Posted: Sat Aug 02, 2008 5:19 am Post subject: |
Does your steering wheel vibrate at idle? If so, motor mounts. _________________ 1987 951 - M193 Version for Japan |
Posted: Sat Aug 02, 2008 5:54 am Post subject: |
Doesn't the 924NA have a little shock absorber ("torque strut") on the exhaust side of the engine? If yours is missing or worn out, may be time to install a new one (but not a new one from Porsche ($$$$$$$$)). They're available on eBay, and I think one or more on the board here have installed them. (-But of course make sure both motor mounts are good first.)
[ http://www.924board.org/viewtopic.php?t=23270 ] _________________ "..it's made in Germany. You know the Germans always make good stuff."
Chrenan
Posted: Sat Aug 02, 2008 6:22 am Post subject: |
There is such a device. From my limited experimenting, it is about as usefull as tits on a bull. _________________ 1987 951 - M193 Version for Japan |
Posted: Sat Aug 02, 2008 6:39 am Post subject: |
Mmmm, tits on a bull. . . _________________ Toofah King Bad
MrJoshua
Posted: Sat Aug 02, 2008 7:47 am Post subject: well, all good info |
engine mount, sounds viable. no vibration at idle anywere though. plus the car runs fairly rich. good place to start. thank you. _________________ MrJoshua
77 porsche 924
79 porsche 924 |
elitejaso
Posted: Sat Aug 02, 2008 1:18 pm Post subject: |
+1 for stuffed engine mount, My car didnt vibrate on idle either only on accelertaion and the it was moving all over the place.
Was a stuffed drivers side engine mount (for u guys passeneger side) most common i think _________________ 1981 924 turbo (daily driver) |
poorsha924
Joined: 13 Nov 2007 Posts: 143 Location: Kansas City Mo
Posted: Sat Aug 02, 2008 10:57 pm Post subject: engine vibration |
Hi ther
I don,t belive this to be a motor mount concern . That would be more noticable @ idle. Could be a worn torque tube support bearing slightly, out or driveshaftor worn out pilot bearing. Fisrt thing go to a small engine repair shop & buy a small engine tachometer (syrometer) Briggs& straton makes them about $25.00 You wll have to have another person helps you . Get the veschile up to where it vibrates ajust the syrometer wire to where it is not moving or as close as you can, should be real close to the RPM on the gauge look at the gauge it will tell you the Hz of the vibration. Depending on the the HZ you can isolate your concern.20 to 60 HZ is drive line or engine 80 to 100 HZ above 150Hz possible tire or wheel. Let me know your finding We Have a EVA at work that I can aceess to tell you what to look for once you can tell me the Hz reading Hope this helps
Poorsha 924 _________________ 79 924S snailshell
audi big bore t-body
16" turbo wheels |
Vince Ponz
Posted: Sun Aug 03, 2008 12:40 am Post subject: |
I had the drivers side [US] mount fail coming home from Pocono Raceway a couple of years ago. Under power it ran well but at idle it sounded as if the valves we being eaten by the pistons.
Broken mount.
Of course there could be other problems. Most of which will be covered by all the rest of the guys. _________________ "Never let them see you sweat"
79 931 Euro stock
88 924S SE
