71vdubturbo
Joined: 28 Nov 2006 Posts: 75 Location: Rolla, Missouri
Posted: Thu Jul 31, 2008 11:06 am Post subject: |
In case anyone outside the US is interested in this... don't be.
| Quote: | | I only sell in the U.S.A. Sorry THANKS |
_________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
Posted: Thu Jul 31, 2008 12:47 pm Post subject: |
Looks like an air to water intercooler, however, I think it is a bit tall to fit over the valve cover of a 931, would have to cut a hole in the hood to make it fit also. _________________ [This Space For Rent] |
alexvex
Joined: 31 Jul 2006 Posts: 420 Location: Seattle, WA (from Indiana)
Posted: Thu Jul 31, 2008 1:12 pm Post subject: |
looks like the stock AWIC out of an old subaru (i think it was subaru that had them.) My friend had one on his datsun. _________________ --Alex--
1992 Porsche 968 (VW 2.5L I5 Turbo swap in the works)
1995 Audi 90 Quattro Sport (4.2L V8 Swap)
2010 Touareg TDI
Past Pcars: 80 931, 87 924S, 87 951 |
Posted: Thu Jul 31, 2008 1:19 pm Post subject: |
Definitely not a modified CGT. The heat exchanger is too tall. _________________ erstwhile owner of just about every 924 variant ever made |
71vdubturbo
Posted: Thu Jul 31, 2008 1:55 pm Post subject: |
Yea Ideola, but it would have been a nice conversion piece if it wasn't too tall. _________________ 1977 Porsche 924 - going away...
2001 Audi S4 - 2.7T, Tip |
Posted: Thu Jul 31, 2008 7:51 pm Post subject: |
As flosho pointed out, it could probably still work provided you were willing to cut up a hood and install a cowling or something. The other troublesome aspect would be the charge air outlet, both in terms of getting it to match up to the location of the throttle body (height wise) as well as sourcing a connecting tube that would interface with the ovoid shape on the IC, and the slightly different ovoid shape of the SI TB, or the round shape of the SII TB.
Still, a very interesting piece indeed! _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Fri Aug 01, 2008 1:22 am Post subject: |
Here is the seller's response to my inquiry regarding dimensions:
| jsenterprise_123 wrote: | | Its about 10 1/2" long, about 9 1/2" wide, about 5" tall. |
Based on that, it's appears to be almost exactly 2x the height of the stock CGT unit. _________________ erstwhile owner of just about every 924 variant ever made |
Martijnus
Posted: Fri Aug 01, 2008 9:12 am Post subject: |
'cant see anything wrong with it'...
so it could be leak as hell.
edit: I put 4 bar of air pressure on my oil cooler and it showed no faults. Any intercooler or heat exchanger should hold this pressure too (oil cooler should take more in my case). _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
