nesty
Joined: 22 Jan 2008 Posts: 75 Location: Bushey, Hertfordshire
Posted: Wed May 28, 2008 8:36 am Post subject: Lowering 30mm |
Hi
I want to lower my 924. Looking at least 30mm all round. Anybody got some recomendations for front springs and shocks. I would like to go lower, but in UK only Porsche shop seem to sell 30mm springs.
Nesty _________________ Porsche 924 2.0 Litre (1982 model),
Porsche 911, 3.2 Carrera |
Posted: Wed May 28, 2008 11:14 am Post subject: |
Try THIS. Quite a bit of height adjustment in that setup, and it uses your stock strut assembly to give you coilover-esque flexibility. _________________ Toofah King Bad
nesty
Posted: Wed May 28, 2008 11:44 pm Post subject: |
Cheers thanks for this. My VW club that I am part of reckon, I should lower it 60mm. Though I am not sure if this would be possible & if the ball joints would take that?
Posted: Thu May 29, 2008 12:58 am Post subject: |
Don't know about the ball joints, but your steering geometry will suffer. The 924 already suffers from 'bump steer' which gets worse as the tie rod angle increases. Some people use heim joints and adapters at the outer tie rod for this reason.
Search the tech section. . .there is an article on this (although it calls for aluminum load bearing components, which I would say is a no-no). _________________ Toofah King Bad
Frank.Ind
Posted: Thu May 29, 2008 2:50 am Post subject: |
Ha! Another dubber with a 924!
From my understanding, late 944 top mounts lower the front approx 1", add in 30mm springs and you've got 55mm right there. |
nesty
Posted: Thu May 29, 2008 7:57 am Post subject: |
I mailed Paragon products about the front struts lowering. Ie how they work, apprently the lower spring perch can thread up and down hence giving a lower ride height. _________________ Porsche 924 2.0 Litre (1982 model),
Vince Ponz
Posted: Sat May 31, 2008 1:06 am Post subject: |
250 lb springs can be bought shortened. I have them on mine and all you have to do is level the car at the rear. The latter is a must. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
nesty
Posted: Fri Jun 20, 2008 7:23 am Post subject: |
| Vince Ponz wrote: | | 250 lb springs can be bought shortened. I have them on mine and all you have to do is level the car at the rear. The latter is a must. |
How much drop do you have on yours?
356speedster
Posted: Fri Jul 04, 2008 2:56 pm Post subject: |
The weltmeister 200 or 250 front springs lowers it 1.25" (32 mm) _________________ 1982 Porsche 924 na My 924 blog
1990 Porsche 928 S4 My 928 blog
1995 Fiat barchetta
2007 BMW 318d M-Sport
2010 Volvo V50 |
Posted: Fri Jul 04, 2008 3:32 pm Post subject: |
To be brutally honest, any strut equipped front suspension will suffer from "bump steer" so adjustment is needed to reduce this effect during normal suspension travel. If you lower the suspension the amount of travel needed doesn't really change that much, just where it occurs. _________________ Stefan
beario
Joined: 03 Nov 2002 Posts: 139 Location: st albans/cornwall
Posted: Mon Jul 07, 2008 9:41 am Post subject: |
my mate in kingsbury must have his v8 924 dropped 100mm for sure its looowwwwwwwwwwwwwwww...sems to drive fine..even with 800 ponies...where in bushey are you...any pics of your car... _________________ theres no replacment for displacement....V8 |
