rear hatch reseal
ltgland
PostPosted: Wed Apr 17, 2002 7:57 am    Post subject: Reply with quote
I am getting sick of sucking in carbon monoxide fumes.
How do you reseal the rear hatch? In the technical section, it looks like it involves messing with the glass, which is way beyond my ability.
PostPosted: Wed Apr 17, 2002 9:45 am    Post subject: Reply with quote
What you need to do is actually to replace the weatherstripping. Expensive, but not difficult. The rear hatch reseal procedure is for re-gluing the glass to the frame of the hatch.
ltgland
PostPosted: Thu Apr 18, 2002 2:38 am    Post subject: Reply with quote
expensive. thats bad.
Easy, thats good. how do I do it?
AznDrgn
PostPosted: Thu Apr 18, 2002 5:10 am    Post subject: Reply with quote
Pull the old weather stripping off and slide the new one on.
ltgland
PostPosted: Thu Apr 18, 2002 5:38 am    Post subject: Reply with quote
what, no glue etc??? cool, even an all thumbs mechanic like me can handle that. I take it I DONT have to remove the hatch?
numbers
PostPosted: Thu Apr 18, 2002 7:05 am    Post subject: Reply with quote
No you do not have to remove the hatch, just open it up, pull off the old seal and put in the new one. Doesn't require any tools, although a rubber mallet can be used to seat the seal firmly. The factory seal is available on EBay, or you can just order similar weatherstripping from JC Whitney for about 1/3 the cost. The same stuff is probably available in GB. You may need to adjust the latch pins on your hatch for a tighter seal also. Just requires a screwdriver and a wrench for the lock nuts.
ltgland
PostPosted: Thu Apr 18, 2002 7:08 am    Post subject: Reply with quote
Thanks, I will get to ordering that soon! It will stop me getting brain damaged from carbon monoxide poisoning!
D Hook
PostPosted: Thu Apr 18, 2002 11:42 am    Post subject: Reply with quote
Be sure to give those locking bolts a shot of penetrating oil before you put too much "umph" on them. I snapped one off on mine. Luckily, I had some spares. Not too tough to find if you go gorrila on it by accident.
jl924t
PostPosted: Thu Apr 18, 2002 1:26 pm    Post subject: Reply with quote
Pay special attention to the area around the hinges. I found this area difficult to get the seal to seat properly. When you pull the old seal off clean the body seam where the seal sits. It's an easy job to do.
John
