Engine removing virgin seaking pointers.....
PostPosted: Thu May 01, 2008 10:14 am    Post subject: Engine removing virgin seaking pointers..... Reply with quote
Just about to remove the 924 engine to add my turbo and spray the engine bay....
Any methods to the madness?
hints and tips?
ways to help me remember what connects where, i have a habit of forgeting?
a graduate mechanical engineer whos never removed a car engine... im as excited/ nervous as a grade 12 virgin going to his formal with a hot date!
1979 NA
my Porsches Arse!!!
Ozzie
PostPosted: Thu May 01, 2008 11:20 am    Post subject: Reply with quote
Label cables, take pics to help re assembly
Its AUTO and its BLACK
Montego Black on black/red
PostPosted: Thu May 01, 2008 11:24 am    Post subject: Reply with quote
good advice..any thing in particulr i need to worry about the order of?..perhaps fuel lines..sparky plug things etc etc
any specific order to removing peripherals..
any amateur mistakes to look out for?
1979 NA
my Porsches Arse!!!
Ozzie
PostPosted: Thu May 01, 2008 11:52 am    Post subject: Reply with quote
cant think of any, but the head isnt real well.. got the flu.
PostPosted: Thu May 01, 2008 1:37 pm    Post subject: Reply with quote
Well, for starters, disconnect the battery before doing anything else
Make sure you have a can or two of PB Blaster or a similar type of penetrating oil.
The NA should be pretty straight-forward to pull. Ditto the label / camera / photo comment. I always kick myself after the fact for not taking MORE photos before and during. You can never have too many. With digital cams, it costs you nothing to snap off a hundred pix from every conceivable angle, and store them for future reference. I can't tell you how many times I've used my own photos as reference and wished I had more closeups, different angles, better light, etc. Then again, you can always ask Smoothie for access to his picture album
As for rookie mistakes...hmmm...don't be in a hurry. Work slowly and methodically. It's not a race, and you have nothing to prove by pulling the motor in 30 minutes flat. If I were in your shoes, I'd be more concerned about getting everything cleanly disconnect and detached. You want to be able to drop it back in with a minimum of your budget going to replace things you broke due to careless removal.
PostPosted: Thu May 01, 2008 1:49 pm    Post subject: Reply with quote
The Haynes manual works fairly well for a US car.
I prefer to lift it out, not to drop it out the bottom.
Soak everything with Liquid Wrench, PB Plaster, etc a day or so before starting the job.
PostPosted: Thu May 01, 2008 3:29 pm    Post subject: Reply with quote
i think we have the euro cars which should be the same.
lots of pics..will do
chain hook on points?
ohh forgot to ask...im unsure the actual state of the engine...When the car was delivered the engine sounded beautiful, as for the internals im not sure about their condition..ie valvae guides seals etc etc.
But me being impulsive i removed the whole interior ignition and all before trying a compression check.. any wasy of gauging the engines condition 1) with it still in the car(igntion dash everything inside has been removed not sure how to crank for a compression test?...2)with engine removed(short of actually pulling the engine apart)
1979 NA
my Porsches Arse!!!
PostPosted: Thu May 01, 2008 10:14 pm    Post subject: Reply with quote
You should be able to hook onto lifting brackets bolted on the intake at its mounting surface.
Remove the engine with the engine wiring harness; one or two multipin connectors at the firewall by the coil.
Remove the engine also with the bellhousing attached - only 4 bolts and easier to get to than leaving it in the car.
Remove or drop the front swaybar for extra forward clearance; likewise remove the rad and fans for room (and helps prevent damage), and the coil.
Don't forget to remove the ground straps at the back of the head! Likewise the heater hoses.
That's all that comes to mind right now...
Martijnus
PostPosted: Thu May 01, 2008 10:16 pm    Post subject: Reply with quote
think three times before doing stuff, be SURE you've removed/loosened everything before you do something.
I don't know what strategy you'll follow, but I haven't touched my gearbox.
I've removed my radiator, crossmember and got the engine out quite easily.
Be sure to have an assistant for the things you need one, like hood removal and navigating the engine whilst hoisting etc.
Try to keep the nuts/bolts together with the pieces they belong to (hence, put the bolts back where you got them and twist the nut on) so you'll be sure what went where...
I didn't do that... and I regret that
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
PostPosted: Thu May 01, 2008 10:52 pm    Post subject: Reply with quote
thanks for the advice guys!...much appreciated
924 racer..any ideas on gauging engine condition?..dont really want to pull it apart if its fine..
1979 NA
my Porsches Arse!!!
bass gt
PostPosted: Thu May 01, 2008 10:59 pm    Post subject: Reply with quote
If you trace back the wire from the starter motor,(the small one, not the batt feed) there should be a connector located around the brake master cylinder. If you open this up and run a wire from the batt to this wire, the started will run, cranking the motor. However, you really need to warm the motor up before a comp test, so see if ou can run some temp wires to simulate the ignition switch.
Steve
PostPosted: Thu May 01, 2008 11:12 pm    Post subject: Reply with quote
Absolutely. In my experience, compression test or leakdown test on a cold motor, or one that hasn't been started within a month or so, will yield inconsistent and unreliable results.
PostPosted: Fri May 02, 2008 12:33 am    Post subject: Reply with quote
In my book - if someone else (other than me or the factory) put it together, it's not in good condition. That select few might be expanded to include a few certified race shops, if I get a chance to sample their wares.
There's no better time to put new bearings in an engine than when it's out of the car. Likewise, to do a headgasket job and lap in new valves, install new valve stem seals.
So that's what I'd do as a minimum; new rod bearings (and check mains, replace if needed), new rings, and re-lap valves and install new valve stem seals. Then you have a NEW motor. Not someone else's idea of a fresh motor (which may involve nothing more than some quarters in the spray wash and a can of spray paint)!
PS - I'd also put in new seals wherever I can get to; rear main, front crank seal, those would be key. So an all-new engine gasket set - gonna want a new headgasket and oil pan gasket.
PostPosted: Fri May 02, 2008 7:39 am    Post subject: Reply with quote
Thanks alot guys!
1979 NA
my Porsches Arse!!!
tuurbo
PostPosted: Sat May 03, 2008 11:44 pm    Post subject: Reply with quote
What they said!
Ideola's comment about taking your time is so true. I'm not saying this as a guy who's done it successfully (although I pulled/yanked/broke one 931 engine years ago), I'm saying it as someone who has had to eat the cost of my own mistakes and those of someone else rushing the job.
Methodical, take pictures, document it...just put a note pad on the roof and jot stuff down on Post Its or a log book, whatever suits you.
Good luck with it!
1980 924 turbo, MSD, Meth. Inj, otherwise stock.
