Weber carbs fuel line
PostPosted: Sat Mar 15, 2008 1:16 am    Post subject: Weber carbs fuel line Reply with quote
I'm planning to switch to Weber 40 dceo and I'm trying to figure out where the extra fuel is supposed to go?
No exit for return line on the fuel pressure regulator or any where else.
PostPosted: Sat Mar 15, 2008 1:25 am    Post subject: Reply with quote
You'll need a different pump, like a Facet. There is no return line, as the Facet is self-regulating to some extent. Some people use a cheap regulator inline as well.
924-76
PostPosted: Sat Mar 15, 2008 1:35 am    Post subject: Reply with quote
I bough the Weber low pressure fuel pump. So the pump just keeps going on and on with no exit except for what goes in the engine?
PostPosted: Sat Mar 15, 2008 2:20 am    Post subject: Reply with quote
Yeppers. . .that's what I did on the 914, anyway, and without a regulator.
924-76
PostPosted: Sat Mar 15, 2008 2:55 am    Post subject: Reply with quote
ok
thank you for the info
