lost power help
bmc65
PostPosted: Thu Apr 04, 2002 1:20 pm    Post subject: Reply with quote
79,924 when it is cold runs good. But when it gets hot it looses power and runs bad. Hard to start.can some one help?
TonyMechanic
PostPosted: Thu Apr 04, 2002 2:47 pm    Post subject: Reply with quote
Try the warm up regulator (WUR) its located on the back (when you've got the hood up and are facing the engine) of the intake manifold, its got 2 wires and 2 fuel lines going to it. Thats just my first thought though. Anybody with more experience have any suggestions?
Diesel
PostPosted: Thu Apr 04, 2002 9:28 pm    Post subject: Reply with quote
Does it ping? Does it smoke?
dpw928
PostPosted: Fri Apr 05, 2002 2:29 pm    Post subject: Reply with quote
The WUR would seem to be the culprit but you may want to start by checking for bad plug wires, loose/leaking vacuum lines to the vacuum advance (front and back) and make sure there are no other major vacuum leaks which would cause you to run lean when warm.
Dennis
bmc65
PostPosted: Sat Apr 06, 2002 9:20 am    Post subject: Reply with quote
no smoke but has a strong smell
bmc65
PostPosted: Sat Apr 06, 2002 9:30 am    Post subject: Reply with quote
Dennis thanks for the help on the fuel distributor
bill
dpw928
PostPosted: Sat Apr 06, 2002 1:01 pm    Post subject: Reply with quote
Bill,
Have you set your fuel mixture? You may be running too rich or lean. If you smell fuel you might try leaning the mixture.
BTW I have sold my 924. I've had it for 16 years and put about 200K miles on it. Haven't driven it much in the last three years and it needs to be driven.
Dennis
