Camber settings for racing
PostPosted: Tue Oct 30, 2007 7:44 am    Post subject: Camber settings for racing Reply with quote
I am looking for the front camber settings for racing/ track use. (924, 1980 2.0i non turbo)
Neil924
PostPosted: Tue Oct 30, 2007 8:06 am    Post subject: Reply with quote
It would depend on the track. -2° could be a starting point, is it an oval or a road course?
PostPosted: Tue Oct 30, 2007 8:15 am    Post subject: Reply with quote
It depend what tires you have on your rims, and how stiff your suspension is. Racier r-compund tires need lots of camber, and slicks even more. I´m maxing out the negative camber at around -3 degrees. Did a huge differens in front end grip. On my track tires of course.
PostPosted: Tue Oct 30, 2007 5:22 pm    Post subject: Reply with quote
Its for a circuit:
My suspension is not very stiff, I do have lower front springs and lowered the back a little. Ofcourse I haven fron and rear sway bars.[/img]
PostPosted: Tue Oct 30, 2007 9:44 pm    Post subject: Reply with quote
Tires are a determining factor, as much as anything... usually the tire manufacturer - if it's a race/track tire - will be able to give a recommendation of at least a range.
That said, with a fairly stock suspension, you'll probably want as much camber as you can get. I run about 3 degrees front, and about the same in the rear.
PostPosted: Wed Oct 31, 2007 2:26 am    Post subject: Reply with quote
is the rear also adjustable camber ?
PostPosted: Wed Oct 31, 2007 8:14 am    Post subject: Reply with quote
Yes, you can adjust the rear to. But not as easy as the front. Search the forum and i think you will find lots of threads.
Nobbi
PostPosted: Fri Nov 02, 2007 8:37 am    Post subject: Reply with quote
Hmmm... sieht aus wie ZANDVOORT..........
Tarzan Bucht.
Lots of sand on the track, because its te dicht bij de Meer...........
Nobbi
