DominicT
Posted: Tue Oct 16, 2007 2:27 am Post subject: 87 924s poor throttle & rough idle |
| Car has been sitting for 5 years and has no low end power and very poor throttle response. Also has a rough idle and car shakes between 1500rmp and 3000rpm during acceleration then smothes out at higher rpm. I have replaced plugs, air filter and changed the oil twice. What else should I do? |
Posted: Tue Oct 16, 2007 9:24 am Post subject: |
Don't start it again until you have checked the balance shaft belt and the camshaft belt. _________________ White 87 924S "Ghost"
DominicT
Posted: Tue Oct 16, 2007 10:55 am Post subject: 87 924s missing |
| I did a compression test and found that cylinder 4 has no compression while the other cylinders have 150psi. Do you think it could be a stuck lifter or broken spring? |
Posted: Tue Oct 16, 2007 11:28 am Post subject: |
Blown head gasket, burned valve, or holed piston are the most likely issues. It could be corroded and stuck rings, but in this case, some compression is usually present.
Do a blow down check to determine which one it is. _________________ White 87 924S "Ghost"
