Diesel Guest
Posted: Fri Mar 29, 2002 3:44 am Post subject: |
I'm putting some in my 78 which didn't come with them. I have some out of a 79. I've found the holes on the wheel arch for 1/2 of them so I'm assuming under the rear seat are more mounting holes. Question is: where do the retractors go, wheel arch or seat area?
Smoothie Guest
Posted: Fri Mar 29, 2002 4:09 am Post subject: |
Mine came with them and the retractors are to the outsides - the wheel arches. If you measure about 7" back from the front edge and along the top surface of the seat, then 3" at a 90 degree angle up (perpendicular to the seat surface)... That's about where your mounting holes for the retractors should be. Are you actually going to put people back there?
'82 924 Turbo, Home Depot boost control, blue windshield washer fluid water injection
[ This Message was edited by: Smoothie on 2002-03-29 05:30 ] |
Diesel Guest
Posted: Fri Mar 29, 2002 5:23 am Post subject: |
Yes! I'm a sadist. Retractors on the outside, eh? I'm glad I asked, I was going to put them on the inside.
