avalanche Guest
Posted: Fri Mar 22, 2002 8:53 pm Post subject: |
My headlights are not working at the moment and I ordered a haynes manual and its still not turned up yet. Does anyone know what relay controls the headlights (not the motor relay) for dipped/mainbeam.
Ryan |
Smoothie Guest
Posted: Sat Mar 23, 2002 7:13 am Post subject: |
Whether the Haynes is going to be of any use will depend on what car you have (and what Haynes). I have an '82 924 Turbo (US spec) and the Haynes book for 924 and 924 Turbo (US book), but; there are quite a few differences between the relays shown in my Haynes and those shown in the owner's manual that came with the car. I'd recommend you look at the owners manual, but; here's what it says in the (US)Haynes: "Headlight flasher and low beam relay" (lower row of relays, first one on the left side), "Extra headlight relay" (lower row, second from left), "Headlight Flasher Changeover Relay (Europe)" (upper row, second from the right side.
For my car, there are no relays on the fuse and relay panel for headlights - don't think there are any anywhere (except for one on the headlight motor which has nothing to do with actual light on/off) and the relay positions I mentioned above are empty (and my headlights work).
[ This Message was edited by: smoothie on 2002-03-23 10:22 ] |
dpw928 Guest
Posted: Sun Mar 24, 2002 3:04 am Post subject: |
The parts and technical reference manual lists part number 111 943 383 C for all 924's (77-8 .
Dennis |
Roger Hall Guest
Posted: Tue Mar 26, 2002 12:22 pm Post subject: |
| check the lever on the steering colum also |
