droog77 Guest
Posted: Tue Mar 26, 2002 4:25 pm Post subject: |
I just removed the right front fender of my 77 non turbo. I removed all of the bolts, except one. In the very front, just under the corner of the headlight. It threads into the fender, and the head of the bolt is not visable. I coulnt see how to remove that bolt, so I just forced the fender off, it was damaged anyway. My question is, how do I get to the back side of this bolt to attatch the new fender? Thanks in advance!
Cheers,Danny
Joined: 29 Jul 2001 Posts: 8811 Location: Royal Oak, MI, USA
Posted: Wed Mar 27, 2002 1:33 am Post subject: |
Remove the rubber strip tucked under the edge in front of the headlight (with the headlight up). You can then fit a 10mm socket with extensions and universal joint into there and turn the bolt.
