BIG PROBLEMS!!!!!
Cone_Eater
PostPosted: Thu Sep 06, 2007 11:51 am    Post subject: BIG PROBLEMS!!!!! Reply with quote
I have a huge problem that involves a story...
I was driving in town and there is a steep hill with a stoplight a the bottom, I am setting at this light waiting to leave and start assending the massive beast. (never had problems climbing it before) I let out the clutch and start, everything seams normal. I shift to secound, still everything seams normal, I shift to third and everything goes wrong!!!! The clutch exploded. I am not sure if this is the actual problem but it seams to fit the standards. The car made a huge pop noise and began to buc and kick. The car can roll out of gear perfectly, but when in gear it makes a horrid catch in the clutch and has a jar.
Any ideas or openions,
Thanks Sam
gohim
PostPosted: Thu Sep 06, 2007 12:44 pm    Post subject: Reply with quote
Put the car up on jackstands and remove the clutch inspection plate.
If you see loose chunks of rubber, then the rubber centered clutch disk has fallen apart.
If you can't see any loose chunks of rubber, then most probably the transmission us busted.
Cone_Eater
PostPosted: Thu Sep 06, 2007 1:06 pm    Post subject: Reply with quote
I removed the clutch inspection grommet and I didn't really see any pieces or rubber, but I saw a lot of dust. I wiped my finger across the fork, looked at it and the dust had a metallic glimmer. I am thinking that the metal shavings can't be good. But I didn't see any chunks!!! Any ideas of what it could be if it wasn't the clutch? I don’t think it is the CV cause it still rolls perfect with the clutch pushed in or if it’s out of gear.
1988 924S: Koni fully adjustables, Short shift kit, head work, exhaust, K&N, Jacobs ignition, Larger Injectors, Performance Chip, 928 wheels with cooper Zeon tires, Momo interior, Etc.....
If its fast enough to go... its fast enough to blow.
PostPosted: Thu Sep 06, 2007 3:04 pm    Post subject: Reply with quote
You may want to check the CVs for rotational play. . .it might not show symptoms unless under load.
Cone_Eater
PostPosted: Fri Sep 07, 2007 10:30 am    Post subject: Reply with quote
How should I do that? Also if it were the CV it would have to make that noise in the rear. It sounds to be from the front, directly after the engine.
PostPosted: Fri Sep 07, 2007 12:51 pm    Post subject: Reply with quote
Maybe your clutch hub has separated from the rest of the clutch disk? That would explain the metal and lack of "pieces"
Cone_Eater
PostPosted: Sat Sep 08, 2007 1:40 am    Post subject: Reply with quote
How do I remove the clutch inspection plate? Also where is it?
Rich H
PostPosted: Sat Sep 08, 2007 2:06 am    Post subject: Reply with quote
Its on the bottom of the clutch bell housing. Its about a 6" trapizium shape with 1 bolt/screw (Wood screw in my case ) You will see the clutch cover plate and the clutch release bearing inside there.
So if its in gear and you push it what happens?
If the clutch is working you will be unable to move it as you'll be trying to turn the engine over (ie: bump/push starting it) If the clutch is not working then you will be able to move the car.
PostPosted: Sat Sep 08, 2007 2:10 am    Post subject: Reply with quote
There's no plate, actually - all you get with the Audi 5-speed is the hole on the side that you already looked through. You'd have a larger opening at the rear if you removed the starter.
I would jack it up and place securely on jackstands and either have someone press the clutch pedal down or rig a stick to hold it down while you crawl under - then use a screwdriver through the side inspection hole and see if you can move the clutch disk up-down (that would be rotating it). If it moves easily, and a lot, then the clutch disk is ruined. Be aware that since the clutch disk, driveshaft, and transmission are all connected, there will be some play felt even with a good clutch disk due to some free-play in the transmission, so you have to discern between the feel of freeplay right there at the clutch and freeplay back at the gearbox while you're doing this. (There'll be the feeling of extra weight (inertia) of all those extra parts if everything back to the transmission is being moved.)
Rich H
PostPosted: Sat Sep 08, 2007 3:39 am    Post subject: Reply with quote
My mistake... I'll go back to '24 N/As...
Cone_Eater
PostPosted: Sun Sep 09, 2007 9:08 am    Post subject: Reply with quote
It’s the clutch!!!!
I put it in 1st and it just started rolling down the driveway.
I think this could be a problem. lol
I am about to get a SACHS clutch, Anybody use this?
What is a good rate from a mechanic for this job?
PostPosted: Sun Sep 09, 2007 11:45 am    Post subject: Reply with quote
8 to 12 hours labor, more if they have never seen one before...
SACHs is OEM, so yes most of us have used it.
Cone_Eater
PostPosted: Sun Sep 09, 2007 3:30 pm    Post subject: Reply with quote
How much power can it hold before it starts slipping? Also I have a brand new slave and master cylinder. What else should be changed while I am at it? Thanks for all the help.
Sam
Cone_Eater
PostPosted: Thu Sep 13, 2007 1:08 am    Post subject: Reply with quote
I have purchased the SACHS clutch kit and it will be done in about three to five days!!! I hate to see her on a trailer. . I got a really good rate on having it installed, $300, and it is being done by a German car specialist. He works on a lot of BMW’s and Audi’s. Is their anything I should know to correctly break it in? I planned on be gentle for about 700 miles just to make sure everything is done correctly. I will keep everyone informed as it gets finished.
Rich H
PostPosted: Thu Sep 13, 2007 3:22 am    Post subject: Reply with quote
I have never broken in a clutch. I've broken a couple though....
