steve1
Joined: 31 Aug 2007 Posts: 13 Location: middleton manchester england
Posted: Sat Sep 01, 2007 2:54 am Post subject: Patience wearing very thin!!! |
Hi there
I`m new to this site but have watched on the sidelines for a few weeks.. I have a european 1982 924 i`m in manchester england. Love the car to bits but...... recently changed the fuel tank (what a job!)the car ran well for about 2 weeks then gave symptoms of running out of fuel while on the motorway.Managed to limp off and car idled roughly and cut out..waited a few mins and tried to start it again.. fired up first time! ran ok again for few mins and de ja vue!!! suspected fuel pump relay so replaced.. along with coil ,plugs,distributor cap, rotor arm and plug leads....still the same!!so you can understand the title of the subject!! patience wearing very thin... any help would be appreciated thanks... _________________ May the porsche be with you!! |
gohim
Posted: Sat Sep 01, 2007 4:52 am Post subject: |
Your 82 should have the same Bosch breakerlss ignition (Hall Effect) module inside the distributor as the U.S. Market cars.
The many of these Bosch modules start going bad at around 100K miles.
The same design from Bosch is used in many other cars, including VW, and Fords, and they all seem to go bad when the engine reach over 100K miles. The symptoms even the same, engine starts fine, runs for a while, acts like it is running out of gas, then cuts out, but you can restart. This does not last forever, eventually if you don't replace it, it will take longer and longer to resart, and one day it won't.
The distributor must be disassembled using a hydraullic press to replace the module. So you will have to either replace the entire distributor, or go to a Bosch Authorized Center where they can service yours, or buy the module, and take the distributor to a mashine shop experienced in servicing distributors (Bosch types). |
Posted: Sat Sep 01, 2007 5:06 am Post subject: |
Whoops. This Coulda-shoulda-woulda been better-placed in General Discussions. 924S Discussions is for a later and different model.
In addition to the ignition suggestion above, my first guess was clogging at either the fuel filter or before one of the fuel pumps - a clog that settles when stopped, then gets pulled up into either the pump or filter after you're running again.
It might also be a bad fuel pump. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Joined: 29 Jul 2001 Posts: 9063 Location: Royal Oak, MI, USA
Posted: Sat Sep 01, 2007 10:06 pm Post subject: |
There ya go, moved it for ya.
Yeah, sounds kinda like the classic symptoms of a dying (overheating) fuel pump. It is conceivable that it's the power circuit for the pump overheating, but usually that happens as a result of the pump dying and pulling too much current. _________________ Vaughan Scott
scottc
Joined: 26 Mar 2007 Posts: 159 Location: Manilva, Malaga, Spain
Posted: Sun Sep 02, 2007 1:50 am Post subject: |
welcome Steve,
I agree with the above, sounds like either the pump or the filter. Filters only about £18 and will probably need changing anyway. |
steve1
Posted: Sun Sep 02, 2007 1:59 am Post subject: |
cheers for all the advice!! The thing that guides me away from fuel is as it coughs and splutters to a dying end..as soon as i immediatley turn the key it fires back up on the first turn of the key .. surely if the fuel is being starved it would take a few turns to bring it back to life as opposed to starting straight away. cheers steve  _________________ May the porsche be with you!! |
Posted: Sun Sep 02, 2007 4:33 am Post subject: |
Take the fuel filter off and drain it. Then shake it, if it rattles, throw it as far away from the car as you can.
Sometimes they fail internally and the loose parts block the flow. As soon as you shut down the pump, the loose parts fall away from the outlet. _________________ White 87 924S "Ghost"
Mike924
Posted: Sun Sep 02, 2007 8:39 pm Post subject: |
Could also be the in-tank pump clogged or not running. Was this replaced with the new tank or is it still the old one? Was it reconnected properly? Was the strainer cleaned out?
Just suggestions. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
1993 Porsche 968 Coupe, Midnight Blue, 6 spd
'There is no substitute for a little grease under your fingernails.' - Chrenan, 924board.org |
steve1
Posted: Mon Sep 03, 2007 3:37 am Post subject: |
yep the in tank pump was cleaned and tested whilst out of the tank. thanks for all the ongoing advice.. _________________ May the porsche be with you!! |
