Posted: Wed Aug 15, 2007 5:19 pm Post subject: installing an oil temperature gauge |
I bought an Golf 1 GTI oil temperature gauge. Wich I want to install in my 924 2.0. There is an extra hole in the carter.
Does any one know of wich car I can use an temperature sender that will fit in the carter ? _________________ 937 trackday car
Posted: Wed Aug 15, 2007 7:13 pm Post subject: |
An oil temperature gauge was fitted to the very early cars. Check your local Porsche agent.
Have you tried a search? There have been a few discussions about oil temperature senders in the past. _________________ 1979 924 (Gone to a better place)
scottc
Joined: 26 Mar 2007 Posts: 159 Location: Manilva, Malaga, Spain
Posted: Wed Aug 15, 2007 8:56 pm Post subject: |
| Theres a bolt in the sump, just above the sump plug. Can't remember the thread of hand, but thats where most people put an oil temp sender. |
Posted: Wed Aug 15, 2007 10:39 pm Post subject: |
To get a correct reading, you need to match the sender with the gauge... so you should get the sender from a GTI. _________________ Vaughan Scott
Posted: Thu Aug 16, 2007 12:18 am Post subject: |
| scottc wrote: | | Theres a bolt in the sump, just above the sump plug. Can't remember the thread of hand, but thats where most people put an oil temp sender. |
You should find that thread size is m14x1.5 (unless it's been re-drilled and re-tapped (which would be unusual )) - http://www.924board.org/viewtopic.php?t=19406 _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Thu Aug 16, 2007 1:43 am Post subject: |
The meter is VDO, 0-150 C celsius.
Can I also use an water temp. sender ? _________________ 937 trackday car
Posted: Thu Aug 16, 2007 7:45 am Post subject: |
924RACR is correct about the sensor. Being VDO you are in luck as I understand they all use the same sensor thermistors with identical temperature coefficients.
Check that your sump actually has a hole since my early one doesn`t, just a cast boss.
Then try:
http://www.germansupply.com/home/customer/home.php?cat=340
Roger |
