Alternater,Starter wiring.
Joes924
PostPosted: Tue Mar 19, 2002 4:01 pm    Post subject: Reply with quote
Well,I was going to fix my car this last weekend, But the family went to central oregon,Bend.We stayed at the townhouse there.Saterday morning I went to Mount Bachelor just a few miles down the road
and snow boarded all day, it was really snowen all day.Had a blast...then went ice skating that night and again on Sunday.Anyway took out my alternator today cause the volt guage was jumpen all over the place staying down in the 10 and under range then going up to where it is supposed to be.Ultimately
discharging the battery to no start.Had the alternator tested it was good so is the battery its putting out alot of amps. The wires from the battery to the starter to the alternator were falling apart. I removed the starter also and went to autozone and bought some 10 and 12 guage wire and and connectors, new (+) battery cable with a 10 guage wire attached to it for additions msd ignition ect. Made a new wiring harness. Ill post a pic. in the morning.It never would stop running but the wipers would slow way down,never tried the headlights Joe D.
Roger Hall
PostPosted: Wed Mar 20, 2002 10:42 am    Post subject: Reply with quote
if there is a short you can try to isolate it by putting a meeter on the battery if there is voltage then the battery is draining pull the fuses one by one when the voltage drain stops you know which circut has the short
Joes924
PostPosted: Wed Mar 20, 2002 10:49 am    Post subject: Reply with quote
I put it all back and theres not enough volts at the battery..9- 10 drove it around and it just drained the volt guage was all the way down. Im taken off the alt, again and checken it again..voltage regulater
gonna have to do something..check the alt. again I guess..
[ This Message was edited by: Joes924 on 2002-03-20 12:23 ]
Joes924
PostPosted: Wed Mar 20, 2002 10:58 am    Post subject: Reply with quote
I didnt connect that ground strap to one of the rear covers ...Ill do that 1st
Roger Hall
PostPosted: Wed Mar 20, 2002 12:46 pm    Post subject: Reply with quote
wich cover
Joes924
PostPosted: Thu Mar 21, 2002 9:18 am    Post subject: Reply with quote
The cover for air to be ducted... anyway
Roger I removed the alt again and had it tested at 2 places(auto zone &and a starter & Alt. rebuild place) thay both said it was bad the 2nd place said it was grounding out so I bought a new remanufactured one for79.00 .Got some pics to post later.
Roger Hall
PostPosted: Thu Mar 21, 2002 11:48 am    Post subject: Reply with quote
sounds like you found the problem just goes to show you cant take someone's word as gospel good luck
Joes924
PostPosted: Thu Mar 21, 2002 3:51 pm    Post subject: Reply with quote
Thanks
