Springs
PORSCHEV
PostPosted: Tue Jul 10, 2007 1:53 am    Post subject: Springs Reply with quote
I lined up a set of front springs from a 944. Does anyone know if these are any stiffer then the 924/931. The guy from the hybrid board sent me this description.
"Ive weighed each one and they are both 5.6 lbs. 5 lbs. 6 ounces.
They are roughly 16 inches non compressed measured from the floor to the top.
The wire diameter is very close to half inch.
Lastly, theres three 1/2 inch white dots painted from the factory on each spring. They are from a 1987 944 NA. "
What do you guys know about the usefullness of these springs?
1978-#53 "D" track racer.
PostPosted: Tue Jul 10, 2007 2:51 am    Post subject: Reply with quote
The answer lies HERE, in some obscure Aussie website.
PORSCHEV
PostPosted: Tue Jul 10, 2007 3:06 am    Post subject: Reply with quote
Well with that usefull chart I found the springs should have 2946N..which might be around 160 lb springs vs the 140lb spring the stock 924 has.
PostPosted: Tue Jul 10, 2007 4:12 am    Post subject: Reply with quote
well like i said in the other thread i've fited the 944 springs on my 924 and it was too high.
here is a picture:
PORSCHEV
PostPosted: Tue Jul 10, 2007 5:34 am    Post subject: Reply with quote
Well that kills that idea
jesse wall
PostPosted: Wed Jul 18, 2007 4:55 am    Post subject: springs Reply with quote
the after market adjustable columns from paragon or other sources will fit your struts fine and you can pick your ,own height and weight springs as needed , check ebay for ones you need Jesse
jesse wall 'new driver' , 87 924s
scottc
PostPosted: Wed Jul 18, 2007 4:58 am    Post subject: Reply with quote
I didn't realise you had a 4x4 924 Morghen.
