ground strap
stexch
PostPosted: Wed Mar 21, 2007 1:03 am    Post subject: ground strap Reply with quote
I was complaining to a friend that my '78 924NA cranks very slowly. He thinks that the problem is that there is a ground strap running to the aluminum cam cover. He suggests that if i move the ground to steel, e.g. the wheel well, I would get a better ground. Another friend said that this makes no difference. Any thoughts?
-nick
PostPosted: Wed Mar 21, 2007 1:38 am    Post subject: Reply with quote
The cam cover studs are tiny, you need a larger gauge strap + eyelet connection! Not to mention that a stud going into aluminum won't conduct as well. I'm amazed it starts at all if this is your only grounding point from the battery?
I run one off the neg battery terminal to an intake mounting stud. And another from the neg terminal to the stock body location in the battery box. The intake stud is iron/steel and conducts directly to the iron block.
1980 931S
1991 964 C4 Cabriolet
stexch
PostPosted: Wed Mar 21, 2007 1:42 am    Post subject: Reply with quote
Thanks for the help! I'll make this change and let you know how it turns out.
PostPosted: Wed Mar 21, 2007 12:55 pm    Post subject: Reply with quote
Use a set of jumper cables to make a temporary connection and see if that helps.
PostPosted: Thu Mar 22, 2007 8:27 am    Post subject: Reply with quote
Wouldn't running to the manifold stud actually be trying to conduct through an aluminium head???
I ran mine to the stud on the firewall and put a short link from there to the battery negative terminal. I also run another ground from the negative battery to the metal bracket that sits just in front of the windhield wiper motor...
!tom
PostPosted: Thu Mar 22, 2007 8:46 am    Post subject: Reply with quote
Aluminum is actually quite a good conductor. It's not much worse than copper, and is a better conductor than steel.
The problem with aluminum is that it oxidises, and the oxidised layer is an insulator. If you have a good electrical contact with the head, I can't imagine there being much of a problem conducting through the head bolts into the block. However, a block ground certainly wouldn't hurt, since it's the connections between conductors that tend to increase resistance.
78 924 NA
5-lug
stexch
PostPosted: Thu Mar 22, 2007 11:16 pm    Post subject: Reply with quote
First, a correction of my original post. As near as I can tell, there are three ground straps:
1. Battery to aft side of intake;
2. Firewall to fore side of intake;
3. Cam cover to shock tower.
I disconnected the battery-intake connection and reconnected it on an unused shock tower bolt. My car now cranks more strongly.
a. There was a bare twisted wire that bolted to the same stud on the intake as the original battery connection. Is it necessary for this wire to be in contact with the one from the battery that I moved?
b . What useful purpose do connections 2&3 above serve?
c. There is a flying saucer shaped thing on my distributor, with a tube going nowhere. What is it?
d. Whatver happened to Timstar?
!tom
PostPosted: Fri Mar 23, 2007 4:21 am    Post subject: Reply with quote
a) This bare twisted wire is likely an original ground. Exactly what parts are grounded isn't terribly important, as long as there are good grounds.
b) Those were multiple grounds, done to ensure that all components are grounded, and grounded well.
c) Sounds like your vaccuum advance. It's pretty important. That tube (if it's what I think it is) should be connected to your intake manifold in some manner.
d) He's still lurking I'm sure.
78 924 NA
5-lug
stexch
PostPosted: Fri Mar 23, 2007 4:43 am    Post subject: Reply with quote
Thanks for your response. Since I'm running Weber carbs, I assume that the vaccuum advance is not functional. Was this part of the emission control system, or was there some other purpose?
PostPosted: Fri Mar 23, 2007 10:18 am    Post subject: Reply with quote
No, it was to advance the ignition to get better spark at high vaccum, some distributors cam with advance/retard... in addition to the mechanical advance bob weights built into the distributor...
The vaccum advance line was normally connected to the throttle body so that it only saw vaccum when the blades were open... IIRC
P.S sorry I was thinking magnetic properties for some strange reason....
Leadfoot
PostPosted: Fri Mar 23, 2007 10:41 am    Post subject: Reply with quote
Electricians use something like this on aluminium connections -
<click>
It's conductive + anti-oxidant.
I found it at the local hardware store for $3.89.
