control arm
berenlotr
PostPosted: Mon Mar 12, 2007 8:09 am    Post subject: control arm Reply with quote
are the front lower control arms interchangable between sides cause iwas going to order one but it doesn't specify side
PostPosted: Mon Mar 12, 2007 8:49 am    Post subject: Reply with quote
I don't think so... as the sway bar mounting locations are sunk into the c.arm... but don't quote me on this as there are two different control arm for the different years, I believe these revolved around the difference in sway bar design/mounting...
That being said could you list what year and model you are talking about, this would make things easier to narrow down...
Leadfoot
berenlotr
PostPosted: Mon Mar 12, 2007 9:03 am    Post subject: Reply with quote
lol 79 924 n/a, forgot to mention that
Lizard
PostPosted: Mon Mar 12, 2007 10:17 am    Post subject: Reply with quote
search the board, but you can use VW rabbit lower control arms, and they are alot cheaper
3 928s,
gohim
Yeah, you can switch the steel arms from side to side.
There are two different numbers because some arms come without swaybar mounts and some come with sway bar mounts.
The arms are built symmetrical so you can use the same part for left or right side, just flip them over.
Same thing if you get arms with swaybar mounts, because again, the mounts are symmetrical, and you flip them over for the other side of the car.
If you are buying used arms, make sure that they are straight, and not cracked. If you have the time, get them seam welded, blasted and powdercoated before you install them.
berenlotr
PostPosted: Mon Mar 12, 2007 10:29 am    Post subject: Reply with quote
yea i found some new ones, lol just got the car started yesterday and i was woking on it today and accidentialy kicked a jack stand and it shifted over below the control arm, when i went to drop the car off the jack it all the weight landed on the control arm and cracked it , thx for the help guys
