Joes924 Guest
Posted: Sun Mar 03, 2002 1:02 pm Post subject: |
I had nothen better to do today than work on my car all day, removed the wheels & the rear konis.Cleaned up the cv boots and joints
& cleaned more stuff[trailing arms etc.On
the front I noticed there is a lot of slack in the drivers side brake rotor figured the clamping nut needed adjusting[removed the brake caliper]cant get the bearing cover off
is the speedo sealing compound maybe holding it on I squirted it up real good with wd40 for the night any suggestions.The brakes were just done last year new master cylinder and rear brake cylinders.
[ This Message was edited by: Joes924 on 2002-03-03 14:06 ] |
Zuffen
Joined: 31 Jul 2001 Posts: 1427 Location: Owasso, Oklahoma 74055
Posted: Mon Mar 04, 2002 2:34 am Post subject: |
First of all did you remove the circlip on the cable end coming out of the cap?
If you did just pry the cap off.
Bob Dodd
14 Porsches and counting.
6 931 two of each year, including a 80S
3 924 77,77,80 all for parts
4 944 82,84,85,86 all for parts
1 sad 912 for parts
[ This Message was edited by: Zuffen on 2002-03-04 03:34 ] |
jamez Guest
Posted: Mon Mar 04, 2002 4:57 am Post subject: |
| they get stuck on there really good, I had to use a hammer, and pound outward on the lip.. but make sure you remove the circlip holding the speedo cable... |
Joes924 Guest
Posted: Mon Mar 04, 2002 1:43 pm Post subject: |
Well I got the bearing cover off just with channel locks I see the groove for the cir clip[it was missing].. The outside bearing
is shot[I ran to the parts place and was able to get another[bearing]. Its all back together again ..Thanks alot
