79porsche
Joined: 12 Feb 2006 Posts: 36 Location: Greensboro, North Carolina
Posted: Wed Jan 03, 2007 7:30 am Post subject: Why do door check straps break? |
Working on my 924 going from one issue to the next...and making progress. One of the next is two broken door check straps. Is this a common issue...and if so....why would they break. I see no reason why these check straps should be broken.
I'm definately going to need to replace these asap. |
Posted: Wed Jan 03, 2007 8:28 am Post subject: |
Door stop straps are a secondary failure part - something else has to go wrong first, then the straps fail. It happens like this...something breaks - waterpump, fuel pump, whatever, leaving the car and occupants stranded on the side of the road 10 or more miles from home. Then both doors fly open with excessive velocity and the straps break as the PPOO (previous pissed-off owner) and PPOOPSO (previous pissed-off owners' passenger seat occupant) exit the car, each in a huff.
Mine are still good (my PPOO obviously preferred punching out the dash and elbowing the center armrest), but door strap failure isn't too unusual. _________________ "..it's made in Germany. You know the Germans always make good stuff."
kojab
Joined: 02 Nov 2002 Posts: 61 Location: Sydney Australia
Posted: Wed Jan 03, 2007 9:52 am Post subject: |
My drivers side (RH) has broken too. I did notice that the passengers door was getting very hard to close and lubricated the door check strap with grease. What a difference a bit of lube makes. Also noticed how badly worn the surface of the check strap was. Maybe they break because the surface hardening is removed from lack of lubrication which then allows them to possibly stretch and then break.
Where can I buy one of these straps?
Richard |
JB 924
Joined: 03 Apr 2006 Posts: 606 Location: Hessen, Germany
Posted: Wed Jan 03, 2007 1:47 pm Post subject: |
| The one on my other car is broken on the driver's side, too. It's because they don't get lubricated, and once the mechanism fails, it can actually rip the door like it had on my 924, and also the Bimmer. |
79porsche
Posted: Thu Jan 04, 2007 5:48 am Post subject: |
| Are the fasteners which hold the strap to the pillar and door a 5 mm (12 point) fastener? Whatever they are...I don't have one. |
Posted: Thu Jan 04, 2007 6:14 am Post subject: |
Its metal fatigue from the low grade pot metal stretching every day for 20+ years. _________________ Toofah King Bad
79porsche
Posted: Thu Jan 04, 2007 7:27 am Post subject: |
| The bolts that hold on the check strap are triple square (12-point) fasteners....but not sure what size. |
Llamaguy
Posted: Thu Jan 04, 2007 8:39 pm Post subject: |
| Rasta Monsta wrote: | | Its metal fatigue from the low grade pot metal stretching every day for 20+ years. |
It's that cheap communist steel buckling under our capitalist might _________________ 1987 924S Guards Red
1997 Suzuki Tl1000 Supersport |
Nobbi
Posted: Fri Jan 05, 2007 3:26 am Post subject: |
On my car all two to get broken and i removed the complete mechanic-stuff from the doors too.I can tell you that heavy stuff makes the diffrence...
(German word for check-strap is Tuerfangband)
Driving without makes live easier.....
Nobbi  |
