Steering Column Bearings - are they VW part numbers
culyatt
PostPosted: Wed Feb 27, 2002 12:23 pm    Post subject: Reply with quote
I need to replace bottom bearings/bushings on my steering wheel column in 82 924.
Is it true that the steering column is based on VW rabbit
If so what are correct part numbers
Diesel
PostPosted: Wed Feb 27, 2002 10:02 pm    Post subject: Reply with quote
The needle bearing on the very bottom is:
113 415 511 There is also sealing rings and rubber mounts but I don't know if you'll need those. I have a steering column if you need it or if yours is being difficult. I find that parts are actually cheaper at Porsche than going to VW. HTH
culyatt
PostPosted: Thu Feb 28, 2002 12:31 pm    Post subject: Reply with quote
Dan,
thanks.
I live in singapore, otherwise would take up your offer. I have about 1 inch play in the column, so believe the rubber mounts have gone
chris ulyatt
Diesel
PostPosted: Thu Feb 28, 2002 11:01 pm    Post subject: Reply with quote
Hey, I'm just happy to help!
